Home > Maintenance & Mods (L322) > Mercedes Sprinter Jack
Strider
After owning my fatty for 3 years and reading numerous posts on the subject I finally got round to buying a Sprinter Jack and adding the ally location pad to it.
I bought a 16mm stepped drill and some M6 grub screws, after drilling the 16mm hole drilled a 4mm hole at right angles then drilled and tapped M6 x 10mm deep at each end of the hole. Pushed in a 4mm x 45mm long pin then screwed in the grub screws each side to close the hole. I know its a bit OTT, bored retired engineer that's my excuse.
Post #497723 5th Dec 2018 10:44pm
Thumbs Up Thumbs Up proper job There is nothing that can't be fixed with a hammer😜😜
Post #497724 5th Dec 2018 10:54pm
Strider
Thanks Thumbs Up
Post #497726 5th Dec 2018 11:03pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Cracking job.
Post #497736 6th Dec 2018 8:15am
Baltic Blue
It makes my bent nail solution look very amateurish. Thumbs Up
Post #497737 6th Dec 2018 8:46am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Strider,
That's a very dangerous statement !
Would you like to join the 'engineering team' for the group buys we have going on supplying these?
Thanks
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #497739 6th Dec 2018 9:00am
Strider
Hi Bushy30,
I know, it was said slightly tongue in cheek, join a Engineering Team ??? didn't know we had one, tell me more.
Thanks
Post #497751 6th Dec 2018 11:40am
Click for Engineering Team Thumbs Up
Post #497768 6th Dec 2018 2:28pm
Strider
One of my friends has decided to add the ally pad to his recently purchased Mercedes Jack, so for those of you prepared to “have a go”.
I bought mine from Creation Motorsport for £9.99 on ebay. I think they are out of stock at the moment with a new silly price of £170+. The holes I drilled carefully by using a hand held electric drill. The grub screws are a bit of a luxury, if you don’t want to go that route just press a pin in, fill the open hole ends with araldite or any suitable sealant. The pin doesn't carry any loading its just to stop the pad falling off.
Post #498428 13th Dec 2018 1:51pm
Baltic Blue
If anyone wanting one adds the advert to their watch list, then they will get an email alert when they are re-advertised at the low price. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #498453 13th Dec 2018 3:35pm
I used the roll pin from the jack to hold the pad on. Drilled a hole just the right size to hold itself in Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #498521 13th Dec 2018 11:14pm
Strider
Good cheap solution Thumbs Up
Post #498566 14th Dec 2018 11:09am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Just treated myself to one of these pads, having murdered 2 rubbers ones previously Sad
Strider, may I ask, how deep did you drill the 16mm hole? Embarassed
(awaits smutty replies)
Post #507761 7th Mar 2019 11:50am
Strider
Hi,
I created a 3D solid model of the pad, from that a manufacturing drawing. Below is a pic of a sectioned view showing the depth of approx' 14.5mm (measured using full diameter not the drill tip.
Post #507775 7th Mar 2019 1:32pm
mrblonde
Cheers Strider, my alloy block arrived today so I’ll be drilling it out this week Thumbs Up
Post #508335 11th Mar 2019 7:39pm
