Home > Technical (L322) > Fuel Heater Activation |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
If I remember right...... I activated mine using Navcoder, but then had to do an instrument cluster reset before it appeared on the screen.
5th Dec 2018 8:05pm |
Something here....have you got the option on the menu?
5th Dec 2018 8:17pm |
Sorry, I mention the cluster reset in this one. Can’t remember much as it’s years ago.
5th Dec 2018 8:23pm |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
No I only have aux vent on the menu |
So according to my other post, you have to enable it in 2 places using the iidtool and then do an instrument cluster reset.
5th Dec 2018 8:31pm |
I have had a quick read of the other posts and have enabled both the Park Heat and Aux Heat, in the different setting menu so now just need to carry out a instrument cluster reset, if i have read right is just the case of disconnecting the battery or is the another option. |
5th Dec 2018 8:39pm |
Its a hidden menu on the bmw system cars, put BMW hidden obc test or similar into google. You need to access test 2 which is instrument cluster. Think there are 21 tests available in total.
5th Dec 2018 8:48pm |
Ok cheers will have a look later and let you know how I get on thanks for you help |
5th Dec 2018 8:50pm |
A bit here, you need Test 2.
5th Dec 2018 8:55pm |
Tried the reset before I left work which worked fine but no change to the screen, so tried again when I got home still no change on the screen will leave the car to go to sleep and see if it's had any effect in the morning. |
5th Dec 2018 10:21pm |
Think you have to turn ignition off and back on after.
5th Dec 2018 10:40pm |
At the moment when I left car it still said Aux Vent
5th Dec 2018 10:54pm |
Not sure then. Just had another search....
5th Dec 2018 11:04pm |
Update from this morning will give it another week and see if it wakes up unless anyone has any ideas
6th Dec 2018 12:02pm |
