![]() | Home > Technical (L322) > Fuel Heater Activation |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
If I remember right...... I activated mine using Navcoder, but then had to do an instrument cluster reset before it appeared on the screen.
Something here....have you got the option on the menu?
Sorry, I mention the cluster reset in this one. Can’t remember much as it’s years ago.
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
No I only have aux vent on the menu |
So according to my other post, you have to enable it in 2 places using the iidtool and then do an instrument cluster reset.
I have had a quick read of the other posts and have enabled both the Park Heat and Aux Heat, in the different setting menu so now just need to carry out a instrument cluster reset, if i have read right is just the case of disconnecting the battery or is the another option. |
Its a hidden menu on the bmw system cars, put BMW hidden obc test or similar into google. You need to access test 2 which is instrument cluster. Think there are 21 tests available in total.
Ok cheers will have a look later and let you know how I get on thanks for you help |
A bit here, you need Test 2.
Tried the reset before I left work which worked fine but no change to the screen, so tried again when I got home still no change on the screen will leave the car to go to sleep and see if it's had any effect in the morning. |
Think you have to turn ignition off and back on after.
At the moment when I left car it still said Aux Vent
Not sure then. Just had another search....
Update from this morning will give it another week and see if it wakes up unless anyone has any ideas
