Home > Technical (L322) > Fuel Heater Activation
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have bought a GAP IID tool a couple of weeks ago and was looking for an other fault due to to my temperature gauge fluctuating Monday I thought it might be the oil temp sender but cant seem to find anything on it on a TD6 engine.
But back to the problem I activated the park heat setting about 2 weeks ago and read that you have to wait for it to activate but when looking and the live result on Tuesday it shows that the heater is not activated I'm a missing something at it works fine when starting from cold but cant seem to get the park heat to display on the screen. Please help.
Post #497693 5th Dec 2018 8:43pm
mjdronfield
If I remember right...... I activated mine using Navcoder, but then had to do an instrument cluster reset before it appeared on the screen.
Sure I did a thread.... so you might have to do the instrument cluster reset.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #497697 5th Dec 2018 9:05pm
mjdronfield
Something here....have you got the option on the menu?
http://www.fullfatrr.com/forum/topic45058.html?highlight=heat 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497699 5th Dec 2018 9:17pm
mjdronfield
Sorry, I mention the cluster reset in this one. Can’t remember much as it’s years ago.
http://www.fullfatrr.com/forum/topic14631....p;start=30 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497700 5th Dec 2018 9:23pm
matlandy
No I only have aux vent on the menu
Post #497701 5th Dec 2018 9:23pm
mjdronfield
So according to my other post, you have to enable it in 2 places using the iidtool and then do an instrument cluster reset.
The cluster reset is one of the tests that are available on the bmw system. You don’t do that bit with a diagnostic tool.
Over 5 years ago for me, so I don’t remember specifics..... 2 settings using iid tool are something like Park Heat and Aux Heat, in different places. You have to do both. Then reset cluster. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497703 5th Dec 2018 9:31pm
matlandy
I have had a quick read of the other posts and have enabled both the Park Heat and Aux Heat, in the different setting menu so now just need to carry out a instrument cluster reset, if i have read right is just the case of disconnecting the battery or is the another option.
Post #497705 5th Dec 2018 9:39pm
mjdronfield
Its a hidden menu on the bmw system cars, put BMW hidden obc test or similar into google. You need to access test 2 which is instrument cluster. Think there are 21 tests available in total.
Done by pressing the left and right buttons on the binnacle in some sequence. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497709 5th Dec 2018 9:48pm
matlandy
Ok cheers will have a look later and let you know how I get on thanks for you help
Post #497711 5th Dec 2018 9:50pm
mjdronfield
A bit here, you need Test 2.
Prob YouTube videos about too
http://www.ideaphile.com/bmw/540-obc.html
I assume the menu option hasn’t changed now you’ve enabled in 2 places? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497713 5th Dec 2018 9:55pm
matlandy
Tried the reset before I left work which worked fine but no change to the screen, so tried again when I got home still no change on the screen will leave the car to go to sleep and see if it's had any effect in the morning.
Post #497721 5th Dec 2018 11:21pm
mjdronfield
Think you have to turn ignition off and back on after.
Does it now say Aux Heat/Vent instead of Aux Vent or similar? It’s not an additional option I don’t think. The car decides whether it’s going to heat or vent depending on the temperature.
That’s all I did. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497722 5th Dec 2018 11:40pm
matlandy
At the moment when I left car it still said Aux Vent
So will have another look in the morning.
Post #497725 5th Dec 2018 11:54pm
mjdronfield
Not sure then. Just had another search....
As you’ve prob seen on the Gap Diagnostic website, it says it may take up to a week to appear on the screen.... but they don’t mention any instrument cluster test.
See how you go then....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #497727 6th Dec 2018 12:04am
matlandy
Update from this morning will give it another week and see if it wakes up unless anyone has any ideas
Post #497755 6th Dec 2018 1:02pm
