Home > Technical (L322) > Fault lights on dash
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Hi Al,
So driving along merrily , then get the dreaded bong and Adaptive front light icon lights up / then get message HDC fault System not available / then Suspension lowering message / then ABS icon / Emergency brake assist icon / then DSC icon comes on , also just checked and the AFS lights have stopped working ?
Not the Xmas lights I want to see,
Any ideas what might have caused all this ?
Thanks
J
Post #497659 5th Dec 2018 3:04pm
J evro
Dash
Post #497661 5th Dec 2018 3:06pm
J evro
Showing AFS light
Post #497663 5th Dec 2018 3:13pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
Low Battery most easily found fault - or a fault in any one of the sensors whose lights show (think yours is a MOST system, so any fault along the line triggers the other "errors" which are not really there.)
Mine was a bit of dirt on one of the prongs of the ABS module (in engine compartment) which triggered all the lights. A quick removal adn clean sorted everything.
Main thing is...
DONT PANIC MR MAINWARING!! Mr. Green Prob Battery low.
Post #497667 5th Dec 2018 3:30pm
J evro
Thanks, will have a look tomorrow in the daylight, though it’s a relatively new battery 👍🏻
Post #497672 5th Dec 2018 4:30pm
loose battery connection?
Post #497673 5th Dec 2018 4:31pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I'd agree, most likely the battery, but you can never tell with these cars. Could be ECU stuff too.
A fault code will help.
Post #497674 5th Dec 2018 4:32pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Definately electrical gremlins.
Systematically check connections and clean them up.
Check battery voltages at rest and engine running.
Wont be expensive but can ne tedious to find.
God luck 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497676 5th Dec 2018 4:48pm
Grofus
Good luck 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497677 5th Dec 2018 4:49pm
Grofus
Hmmm seem to have gremlins of my own Laughing 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497678 5th Dec 2018 4:50pm
start at the battery terminals Thumbs Up
check battery voltage
then check alternator voltage.
etc etc etc There is nothing that can't be fixed with a hammer😜😜
Post #497680 5th Dec 2018 5:29pm
J evro
Thanks Gents,
Will be back with it tomorrow so will try your points given then 👍
Post #497682 5th Dec 2018 5:45pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Have you got a code reader with any codes??
I have a yaw rate sensor open circuit code that I can’t rid
Post #497694 5th Dec 2018 7:47pm
J evro
Gents,
Checked battery :
At rest 12.08,
Idle 12.24
Does that sound about right?,
Battery terminals are tight,
Now to look at the other connections 😩
Thanks again for your replies👍🏻
Post #497840 7th Dec 2018 2:42pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Any further progress with this?
I’m in the same boat ! 2014 vogue se
Post #497841 7th Dec 2018 2:45pm
