![]() | Home > Maintenance & Mods (L405) > fueling, if i open pump too much fueling stops, |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
maybe it needs resetting..info in the manual? |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Sounds like the unleaded wrong fuel thing has deployed. Assume your a diesel? Yellow plastic reset tool in tool kit to reset it. Cheers
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1249 ![]() ![]() |
I had this problem, virtually running on fumes when I first bought the car.
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 ![]() ![]() ![]() |
Have the same issue on mine. Definitely not the missfuel trigger, checked by dealer twice. It is the modern fuel pumps that have been set to deliver at a higher pressure. My local Tesco was fine until they replaced all the pumps, same at other ‘updated’ forecourts.
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
Cheers all will try the suggestions, seem i am not alone with this one ! |
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 ![]() ![]() |
Mine does this, when filling turn pump handle through 180 degrees and problem solved |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
We have the same problem with ours sometimes, and that's a 2003!! Seems to be the fuel being delivered at high pressure which builds up back pressure in the tank, rotating the nozzle helps, as does smacking the rear panel of the car until it 'burps'! |
