![]() | Home > Technical (L405) > how to disable keyless entry. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
very interesting - nice find Stan |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 887 ![]() ![]() ![]() |
Doesn't work on my 2014 either. |
over on the disco forum - they use the same procedure and seems to work. However on the RR Sport forum - someone has mentioned for it to work the ignition has to be on when you do the sequence. May be worth a try on the RR. |
palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42 ![]() ![]() ![]() |
Worked on my 2016 AB after a couple of attempts 2008 Vogue Black - gone
smartymarti Member Since: 01 Aug 2012 Location: Durham Posts: 32 ![]() ![]() ![]() |
You need to be inside car with Driver’s door open no ignition on , worked,on my 63 vogue |
Kace Member Since: 08 Sep 2018 Location: London Posts: 13 ![]() ![]() |
Did mine today. Had to be inside the car, with the driver door open.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
As above.
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Doesn't seem to work on my MY17. '17 Range Rover 5.0 Supercharged AB (Sold)
Drksde Member Since: 22 Jul 2019 Location: Surrey Posts: 68 ![]() ![]() |
8 range rover models stolen in the last 14 days in my surrey town ..... just turned off the key less function this worked straight away in my 2016 RR, drivers door open ignition not on and follow the sequence ... the headlights will flash 3 times and the doors no longer respond to touch. Fingers crossed ... also I make sure my drive way gates are closed every night. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
Worked fine for me Geoff |
slightly off topic but also make sure you superlock the FF by double pressing the lock button on the keyfob, or you can configure 'one press superlock' via the iidtool.. ... - .- -.
tomo141 Member Since: 22 Aug 2017 Location: UK Posts: 87 ![]() ![]() |
Works on mine - MY13 |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
If your keys remain in a faraday pouch are there any other security benefits in disabling the keyless entry ?
