![]() | Home > Technical (L405) > how to disable keyless entry. |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 176 ![]() ![]() ![]() |
Following a neighbour 'losing' his Focus RS overnight on Saturday, I spent over 45 minutes trawling through the handbook in my Wife's Disco Sport, to find out how to do this, to no avail. Googled the question, watched a 75 second video, and did it, exactly as Stan's posting. I did my own on the day I took delivery a year ago. I also did my Daughter's Evoque yesterday, same process.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
stops the internal module from broadcasting... ... - .- -.
Jases4x4 Member Since: 29 Jan 2021 Location: Yorkshire Posts: 10 ![]() ![]() ![]() |
Thanks stan, so does that means the thieves could still scan and get your signal from your key? Can they then store it and use it another time when maybe you then reactivate the module, Or even worse could they make a key from the key signal and then just press the unlock button? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
For others benefit this worked on my 2019 MY car and didn’t need ignition on. I did sit in the car to do it.
MickLR Member Since: 27 May 2017 Location: London Posts: 18 ![]() ![]() ![]() |
Done mine as Stan said about 45 seconds. |
