![]() | Home > For Sale & Wanted > [sold] 2 in 1, BM54 with Gen 13 ULF built in Hands Free |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
I have for sale my own BM54 from my car. Will fit only the L322 2001-2004 models.
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 ![]() ![]() ![]() |
Have you ever sold it? |
Yes it sold. Did you want something similar? Let me know and we can discuss which upgrades you would want on it. barisahan@gmail.com |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Not being rude but with the age of these things isn’t it better to put a nice big 10.25 Android with a skin in? If you use ibus app and a resler interface you keep all the functions too and can control the dsp settings? You could do the whole thing for under £300 and have carplay and Android auto too and a much more modern unit? Current stable:
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
This is for the BM54 amp with stage 2 upgrade. It’s just a sound system upgrade, not screen, so not really comparing apples with apples. I had one in my TD6. You are not gonna get that upgraded sound from a new android head unit. Not unless you add more amps.
But the dsp amp takes a low level input? So surely longs your Android unit has high voltage outputs it would achieve the same? Current stable:
I don’t believe the DSP unit will power on if it doesn’t see the BM54 on the ibus, but I see what you mean. The DSP is an active crossover so needs to be there unless the whole lot is being replaced. Though I’m no expert on the android stuff. I’m sure someone will have written an app to manage the DSP. Things have indeed moved on, but you will need to invest in more than just the android head unit if you want to compete with the stage 2 BM54 sound wise. I’m sure it can be done. The stock speakers aren’t brill, but wake up with the upgraded amp.
Yes you need a resler interface and the ibus app then it wakes up the amp and can be controlled more so than stock - it sounds great providing you have a half decent dac in the Android unit - far better than the stock that’s for sure, I had it setup in my 02 this way for a bit.
