Home > For Sale & Wanted > [sold] 2 in 1, BM54 with Gen 13 ULF built in Hands Free
Baris
I have for sale my own BM54 from my car. Will fit only the L322 2001-2004 models.
Its a fully loaded BM54, with the following.
Stage 2 Amp Upgrade 20 watts (stock) to 50 RMS watts per channel
Firmware upgraded
Bluetooth Music Streaming, via Auxiliary mode.
2 x RCA preouts for sub and amp installation.
12v remote wire for amplifier
Built in Generation 13 ULF Bluetooth Hands free
Pairing button (1 meter long, but can buy an extension, if you wish to divert to the cabin area. Can just pair from boot, and leave it for next time you change phones)
Microphone (5 meters long cable)
Bluetooth Receiver
Once the BM54 is plugged in, you will get the telephone option on your monitor, and your telephone options on the steering wheel will work and you will have factory fitted hands free. Will work with any phone, as its the latest generation 13 ULF.
Looking for £515 + £10 postage. barisahan@gmail.com
Post #496297 22nd Nov 2018 4:56pm
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Have you ever sold it?
Post #591984 21st Apr 2021 11:50am
Baris
Yes it sold. Did you want something similar? Let me know and we can discuss which upgrades you would want on it. barisahan@gmail.com
Post #591990 21st Apr 2021 12:50pm
hbthepilot
Good evening Baris,
jup looking for something similar - top priority is music AUX or preferably Bluetooth!
I do have TV Tuner and Phone installed.
Cheers
Post #592035 21st Apr 2021 9:28pm
Danwilderspin
Not being rude but with the age of these things isn’t it better to put a nice big 10.25 Android with a skin in? If you use ibus app and a resler interface you keep all the functions too and can control the dsp settings? You could do the whole thing for under £300 and have carplay and Android auto too and a much more modern unit? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592144 22nd Apr 2021 7:32pm
mjdronfield
This is for the BM54 amp with stage 2 upgrade. It’s just a sound system upgrade, not screen, so not really comparing apples with apples. I had one in my TD6. You are not gonna get that upgraded sound from a new android head unit. Not unless you add more amps.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #592163 22nd Apr 2021 9:21pm
Danwilderspin
But the dsp amp takes a low level input? So surely longs your Android unit has high voltage outputs it would achieve the same? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592167 22nd Apr 2021 9:48pm
mjdronfield
I don’t believe the DSP unit will power on if it doesn’t see the BM54 on the ibus, but I see what you mean. The DSP is an active crossover so needs to be there unless the whole lot is being replaced. Though I’m no expert on the android stuff. I’m sure someone will have written an app to manage the DSP. Things have indeed moved on, but you will need to invest in more than just the android head unit if you want to compete with the stage 2 BM54 sound wise. I’m sure it can be done. The stock speakers aren’t brill, but wake up with the upgraded amp.
I suppose if you are not that into music, an android unit on its own will sound ok. Plenty of folk just do that and are content. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #592173 22nd Apr 2021 10:35pm
Danwilderspin
Yes you need a resler interface and the ibus app then it wakes up the amp and can be controlled more so than stock - it sounds great providing you have a half decent dac in the Android unit - far better than the stock that’s for sure, I had it setup in my 02 this way for a bit.
The later hk speaker 05+ are brilliant I have actually ditched the logic 7 amp and run a proper amp and the stock speakers really come alive I was actually quite shocked I had factored in them blowing up and needing replacements. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592174 22nd Apr 2021 10:43pm
