Home > Technical (L405) > Power steering failed L405
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Just wondering if this is common?
Stopped at the traffic lights and the stop start engaged, when the lights changed to green I pulled away and had no power steering!!! managed to pull around the corner and stoped, I turned the car off and restarted, when restarted it was fine??
This happened last week and it has not happened since however I was wondering if anyone else has experienced this???
Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #494546 3rd Nov 2018 9:27pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
I am not a mechanic, but the first thing to check would be the fluid in the reservoir, check for any obvious fluid leaks, then book it in for a check over. My money would be on a small PS fluid leak. I have an old SL55 AMG which has a very slow leak somewhere in the suspension system which eventually causes the system to throw an error. Takes about 3 years for this to happen after a top up of fluid - maybe your PS fluid is doing the same?
Post #494869 7th Nov 2018 9:04am
GraemeS
Does it have electric steering?
Post #494871 7th Nov 2018 9:12am
1959terry
I believe that it is electric but it may also have a oil reservoir?
Forgot to mention that I have fitted a Ghost immobiliser recently which connects into the Canbus, I wonder if this may have caused it?
btw it has not re-occured since. 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #494951 7th Nov 2018 9:40pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Sounds more like the vairiable pressure side of ut is playing up... i would be suprised if its the power steering system. It's possible there is a faulty solenoid valve that controls the pressure. When your under 18mph it's on full power I.e. easy to steer and park, as speed increases the pressure backs off to provide the driver a more positive feel on the road. My money is on some kind of sensor that controls it. I would get it plugged in and pull off a diagnostic fault code Thumbs Up
Post #495846 17th Nov 2018 9:53pm
1959terry
Thanks for your input Charles.
It has not happed again since and I now have it booked in for a service and MOT. I will see what they say. 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #495876 18th Nov 2018 10:36am
millerj90
Thread Resurection - L405 Power Steering
Quote :- "Stopped at the traffic lights and the stop start engaged, when the lights changed to green I pulled away and had no power steering!!!"
Exactly the same for me. Anyone else had this or did the OP ever find the reason?
Post #587311 13th Mar 2021 3:31pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Exactly same thing happened to me called out landrover assist and says it’s a common fault and points issue to earth cable connections in the boot which dealer checked and cleaned earth strap connections and re calibrated software and had no problem since 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #587350 13th Mar 2021 7:15pm
millerj90
Aljo - many thanks for the update. I’ll dig around and clean up the connections. It’s annoying but at least it’s a cheap "failure".
Post #587382 13th Mar 2021 9:22pm
aljo
There is a tsb bulletin regarding this
Will see if I can find it Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #587384 13th Mar 2021 9:46pm
millerj90
Cool. Many thanks.
Post #587394 13th Mar 2021 10:43pm
millerj90
I think I’ve found it. It’s SSM 71278.
Issue:
A customer may report the vehicle steering feels heavy following an ECO stop start event, potentially accompanied by visual or audible warnings through the instrument pack. The following DTCs may also be logged:
Range Rover/ Range Rover Sport 1GMY only
EPAS module -
B1304-16: Electronic Power Assisted Steering (EPAS) system circuit voltage below threshold.
Range Rover/ Range Rover Sport/ Range Rover Evoque/ Discovery Sport EPAS module -
U3001-00: Power Steering Control Module (PSCM) system improper shutdown. These may be accompanied by:
U0001-87 I 88 High speed CAN bus invalid serial data received/ missing message. Chassis Control Module -
U0131-00 Chassis Control Module (CHCM) lost comms with PSCM.
U3003-62 Battery voltage signal compare failure.
U0420-68 CHCM invalid data received from PSCM.
B1304-04 Electronic Power Assisted Steering System - System Internal Failures
Cause:
This may be caused by:
Low battery voltage at PSCM particularly during engine crank.
Wiring harness issue (short I open circuit, high resistance).
High resistance at EPAS earth terminal (for L405/L494) G1D132 and or G4D178, (see attached diagram) or (for L550/L538) high resistance at G1D122A, G1D122B, G1D122AZ and G1D108.
Poor connection or pin set condition at connector number C11-G1.
Post #587420 14th Mar 2021 11:44am
aljo
That’s the one 👍👍👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #587435 14th Mar 2021 2:43pm
