Home > Maintenance & Mods (L322) > flat battery
paul70
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
flat battery
Car won't start after week away did the same after 2 weeks away in summer. Looking at batteries on Halfords web site it list HSB019 Yuassa whick is non AGM. Battery is currently LR genuine AGM! which is correct for 2011 4.4 TDV8 vogue or is either OK?
To confuse further some others list both but only AGM for start stop - mine isn't
Thanks in anticipation
Post #494403 2nd Nov 2018 12:36pm
Baltic Blue
It needs to be an AGM battery, even though 2011 4.4 tdv8’s aren’t stop/start.
Post #494409 2nd Nov 2018 1:08pm
my agm cost around £225 from JLR....more than other suppliers but circumstances dictated that i had to get one from them..
Post #494411 2nd Nov 2018 1:11pm
Baltic Blue
As Mr Bean says, prices vary widely, but so do guarantee periods.
I paid £189 back in June, but my main thought was , it came with a 5 year warranty. And free next day delivery.
Post #494412 2nd Nov 2018 1:23pm
paul70
Thanks for the replies. RAC on way to jump me off so I'm sorted for today at least. Will order a new AGM online I'll see if Advanced have one in they look the way to go.
Paul.
Post #494414 2nd Nov 2018 1:39pm
Baltic Blue
If you look just in front of the battery, you will see you need a special 5 point torq bit to remove the charging unit.
The RAC man may have one and loosen them for you , otherwise cheap from eBay.
Post #494416 2nd Nov 2018 2:00pm
paul70
Right finally got time and right weather to fit my new battery this morning. (Went for the Varta recomended by Baltic Blue).
Attached the gap tool to tell the car it has a new battery.
service/test, bcm body control, battery replacement and it did a procedure but didn't give the option to inform it what battery it had been replaced with.
Is this correct and it just detects what battery it is itself or am I in the wrong area on the gap tool?
Thanks
Paul.
Post #497324 2nd Dec 2018 2:09pm
i think its in the service menu....
Post #497327 2nd Dec 2018 2:50pm
Baltic Blue
Still not told mine and it seems OK.
Post #497329 2nd Dec 2018 3:20pm
paul70
Ah found it!
My battery is 95ah 850A (EN),
However the nearest I can find is "H8HD 90Ah 950 cold cranking ampere" which it is already set to so I guess I'll leave it set to that unless you can set a custom one up? There is one called 'undefined' but it doesn't appear to give you any options.
I did spot DRL's in the settings whilst in there so have got them switched on now!
Must admit I love the GAP tool has been useful on a number of occasions already.
Post #497330 2nd Dec 2018 3:35pm
Baltic Blue
Paul,
Does DRL just switch on front sidelights when ignition is on/engine running ?
If Yes, please share menu location.
Post #497332 2nd Dec 2018 3:57pm
paul70
It does just turn front side lights on there is also a Scandinavian setting which I think puts the headlights on. I’ll check the exact menu location when I get home.
Post #497341 2nd Dec 2018 5:27pm
paul70
Car config, bcm body control, DRL standard. Change to active.
There is Scandinavian and also Canadian so don’t know what the difference is!
Post #497352 2nd Dec 2018 7:35pm
DrRob
Mike.
Mike
Is this one the same physical size and CCA as standard? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #499052 18th Dec 2018 7:46pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Mike.
Sorry to jump in on this thread, but why would you need a stop/start battery on a 4.4 which is not a stop/start model, i asked because i may need a battery for my Westie which has not been started for 2 mths.
Post #499055 18th Dec 2018 7:57pm
