![]() | Home > Technical (L322) > Fuel Burning Heater Sound |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Pull the fuse!
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
As Joe said pull the fuse and problem sorted |
phn Member Since: 10 Aug 2018 Location: Norwich Posts: 27 ![]() ![]() ![]() |
Cool - thanks for the replies chaps - a great and simple solution!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
remember that the fbh actually helps to warm the engine when cold so it might be worth to leave it alone.... |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
On the Ford Galaxy with the VW 1.9PD engine, the engine produced such a small amount of heat without the FBH you couldn't get warm inside the car, the FBH was running all the time in the cold weather unless you were on the motorway. BMW i3 Electric Car
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Mine was running on mine tonight as I only did a few short journeys.
