Home > Group Buys > Reversing LED bulb (CanBus) |
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 |
All done, paid for 2 sets, Merry Xmas. |
25th Dec 2018 10:14am |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
Happy Christmas all, just fitted my bulbs, Christmas present to the thing. !! Camera doesn't pick up the difference but it is definitely discernible with the naked eye. Happy Holidays all |
25th Dec 2018 2:10pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
I've had to change back to the standard bulbs as these LED bulbs caused the AV screen to flash on/off, mucho beeping and an occasional totally black screen when using reverse.
28th Dec 2018 12:42pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
How very odd! no-one else has reported such behaviour, you do occassionally get the LED's to twinkle at start up, but nothing that effects the camera.
28th Dec 2018 1:22pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
That would be my guess too Bushy.
28th Dec 2018 6:03pm |
Reversing camera looks to be standard issue factory fitted to me - if it has been changed out, it's certainly not anything special.
28th Dec 2018 7:43pm |
No, not the dash, when the ccts are tested on startup the LEDs flash Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Dec 2018 7:45pm |
It won't be a coincidence. The Leds, by their nature will produce interference. But, the camera can only be affected if it has a wired link somehow. The obvious one being it live feed wired into the reversing light circuit. Even a shared ground would do it. I went through all that with my camera upgrade. Check how the camera is wired in chap. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
28th Dec 2018 8:35pm |
OK, Thank you. Will check. |
28th Dec 2018 9:18pm |
Right, Reversing Camera does not work at all now, just a black screen - even with the old bulbs in. Perhaps I disturbed some wiring when changing the bulbs (you know when you wish you'd never bothered)? Although both reversing lights do work, the camera doesn't.
29th Dec 2018 12:31pm |
You need start a new thread for the problem. I will help where I can 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
29th Dec 2018 2:26pm |
Agreed Grofus, new thread, preferably with piccies or wiring which will mean a lower tailgate strip down Current: 2011 FFRR Vogue SE 4.4 TDV8
29th Dec 2018 3:13pm |
dantesdango Member Since: 27 Feb 2014 Location: Virginia Posts: 3 |
Happy New Year all.... Bushy, can you PM me the cost to ship 2 sets to the US please? Thanks. |
1st Jan 2019 9:24pm |
Right folks I have one pair left which should go to Scotty -- I'll PM you!
2nd Jan 2019 12:38pm |
