Home > Group Buys > Reversing LED bulb (CanBus) |
Blueboy1 Member Since: 11 Oct 2016 Location: Cumbria Posts: 15 |
Hi Bushy
16th Mar 2019 7:48pm |
CY88 Member Since: 05 Feb 2015 Location: Offshore Posts: 14 |
Hi, just registered if you have any left? Ta. |
18th Mar 2019 4:21pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
PM's sent to both Current: 2011 FFRR Vogue SE 4.4 TDV8
18th Mar 2019 4:36pm |
Hi, received the bulbs today and changed them - worked great for all of two minutes and then both failed. Bulb error on diagnostics which needed to be cleared with GAP tool, now the LEDs will not work at all? When I put one LED in with a normal bulb and it cuts the power to both. Any ideas?
26th Mar 2019 7:56pm |
Hello Sir,
26th Mar 2019 9:33pm |
I don’t think it’s the fuse, as when I put both the old bulbs back in all works fine again |
26th Mar 2019 10:30pm |
Ok, well not the fuse then.
27th Mar 2019 12:29am |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 83 |
Hi Bushy
29th Apr 2019 11:06pm |
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 |
Hello
15th Aug 2019 9:48am |
Hi John,
15th Aug 2019 10:14am |
Thanks Bushy, I will definitely have a pair when you do.
20th Aug 2019 10:29am |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 |
Can I nominate myself for 2 pairs please |
15th Sep 2019 1:14am |
I ordered the COB lights as well, just in case! FFRR
16th Sep 2019 2:45pm |
You can always mount both - then it will be bright 2011 TDV8 Vogue SE |
16th Sep 2019 2:50pm |
