Home > Technical (L322) > Strange electrical problem.
Jim_m_kidd
2015 Range Rover Autobiography SDV8 Loire Blue
I’ve done a search but can’t find anything similar which is strangely worrying!
Last week I parked up, shut down got out of the car, mrs went to open the boot and said it didn’t work - I’m like ‘are you sure you pushing the right bit’ went to have a look and sure enough boot wouldn’t operate.
Got back in the car and everything was dead, no electrics at all. So I’m thinking dead battery... however I faffed around under the bonnet for a couple of minutes, went back to drivers seat and everything had come back up!
Locked up went to see the Falkirk Wheel, came back - started first time, and has since most of the time.
In the past couple of days though it’s happened again several times.
It is like when I switch off the ignition the battery disconnects, the car loses power but seems to reset/reboot itself.
When I does this I can hear a ‘slightly mechanical’ sound that is not there on a normal shutdown.
After it goes dead I normally need to do something to wake it up, sometimes simply reinserting the key does the trick. Sometimes you stick they key in but the lock doesn’t activate, so opening to door or waiting a few minutes allows the reboot cycle to happen.
Once’s it rebooted, starts fine and strong but radio presets and trip counters reset. But starts fine.
Strange one, can’t find any reference to it so I am hoping that someone’s had similar and can point me at what the fix might be.
Or appreciating I’ve some more diagnostics to do if anyone has some starting suggestions!
Post #488089 5th Sep 2018 6:58pm
Paul thornton
Sounds like you've got an iffy battery connection or your battery is failing.
I'd disconnect the battery terminals and clean them up but before you reconnect it also clean the main body earth terminal.
I'd also suggest getting your battery tested.
Post #488094 5th Sep 2018 8:05pm
Vegasshawn
United States 2009 Range Rover HSE 4.4 V8 Barolo Black
Did you ever get this figured out I'm having the same exact issue with my 09
Post #497287 1st Dec 2018 11:15pm
Gsxr1250dave
Battery earth strap is common failure point
Post #497290 2nd Dec 2018 12:25am
Vegasshawn
Are talking about the one from the neg terminal to the frame or the one down by the starter?
Post #497291 2nd Dec 2018 1:44am
