Home > General (L405) > 165 Point Check ?
Mine is nicer to look at though, pictures and everything! #:bray:#:munch: .
Post #485268 5th Aug 2018 9:24pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Please walk away from the dealer - and indeed name them here.
In fact don't just walk away, tell them you are going to walk away and why. Dealers will only learn when it starts to hit them in their bottom line.
I had a very interesting conversation recently on holiday with someone who said they worked for Jaguar Landrover on the sales side of things working with the Main Dealer franchises. While professionalism limited what they could say, it seems that JLR know they have a problem with many franchises attitude to customers but there is little that they are either prepared to do or in fact can do....as long as targets for the number of new units sold are met.....
As I say, dealers will do little to change their customer service until their bottom lines start to get hit and dealer principals (or whatever they call themselves these days) can't spend as many days on the golf course. Laughing
Post #485380 7th Aug 2018 11:30am
Nig
United Kingdom 2014 Range Rover Vogue TDV6 Indus Silver
I bought a LR approved L405 in March and within 50 miles I noticed a stone chip in the windscreen on the passenger side, I hadn’t noticed this on inspection prior to purchasing the vehicle. After checking the vehicle service history of could find no record of the brake fluid having been changed, on contacting the LR dealer they said bring the car back and we will replace the screen and change the brake fluid, during the journey to return the car I found the air con not to be working, I told them on arrival and told me it would be fixed, it was. These things should have been picked up on the “165 point” check in the first place but fair play to the LR dealer the faults were rectified with no quibble. The car has now developed a small vibration (4 months after purchase) under braking and offside front disc is corroded around the circumference about 25mm down the disc, again no quibble from the dealer on replacing front discs and pads FOC. I have no doubt different dealers offer different levels of customer service, I can’t complain about mine now I have found the correct people within the organisation to speak to instead of speaking to someone who has no idea what they are talking about and tells you to “ring Land Rover assistance “ or “we don’t do investigative work on a Saturday”
Post #485393 7th Aug 2018 2:59pm
gettingold
As above, walk away. Why would you put yourself in that situation and give them your money. Be the sensible buyer and find another car at another dealer, but let them know why. Don't get sucked in.
Steve.
Post #485396 7th Aug 2018 3:52pm
Nooney787
Is there any chance that you could re-post the 165 point check in a less compressed form please Baltic Blue?
Post #502897 26th Jan 2019 10:16pm
Baltic Blue
If you PM me an email I will send it to you as a PDF, but it will have to be tonight or tomorrow, because I am going away for 4 weeks early Monday morning.
Mike.
Failing that you could ask Stan to send you a PDF copy.
It is item 1 in the maintenance section of the 2011 Workshop Manual. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #502899 26th Jan 2019 10:30pm
its in the wiki chaps... Wink
Post #502901 26th Jan 2019 10:39pm
Foz01
Based on some approved cars I have looked at they have absolutely not had the check, they get washed and hoovered and bunged on the forecourt, certainly appears that way Whistle
Post #502945 27th Jan 2019 12:50pm
Thought I had posted these previously
FULL
BLANK (roll your own)
Have available in spreadsheet format as well, if required .
Post #502951 27th Jan 2019 1:27pm
Nooney787
I suspect that the check doesnt get done until the car is sold! Dealers rely on basic checks when they buy the cars in and use the 165 point check as a selling point and a way of ‘PDIing’ the cars. I’ve looked at the one in the Wiki section of this site and can see it’s been ‘done’ by the ticks - must’ve been a perfect car as nothing whatsoever needed any attention Rolling with laughter
Post #502962 27th Jan 2019 3:31pm
