Home > Maintenance & Mods (L322) > [SOLVED] Errors from 2010-2012 Rear Lights
Woofster
Canada
Hey Joe90, just curious if you've done any additional troubleshooting for your rear lights over the course of the past week. It'd be interesting to see how this is ultimately resolved!
Post #485568 9th Aug 2018 6:36pm
Tested tail lights today, 1/2 hour drive to work with full lights on, same journey back with just sidelights on, no fault messages, so looks like the turn off of hot monitoring has worked for that.
So only issue to resolve is the hyperflash of the indicators on first use. .
Post #485575 9th Aug 2018 8:09pm
have you tried switching off cold monitoring to solve that? ... - .- -.
Post #485599 10th Aug 2018 6:15am
Next job, H+C monitoring off to test on indicators .
Post #485602 10th Aug 2018 7:32am
Sorted - All H+C monitoring set to NO for front and back and side.
Indicators work as expected, just have to go old school and check the flashers from the outside ! .
Post #485716 11th Aug 2018 2:56pm
i asked my wife to check the indicators once,.....i said are they working, she said, yes,no,yes,no,yes,no.......... ... - .- -.
Post #485720 11th Aug 2018 3:56pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Yes Stan however it would all depend on the speed/velocity of the yes/no. Rolling with laughter
Post #485721 11th Aug 2018 4:16pm
Laughing Laughing Laughing
Post #485752 11th Aug 2018 7:43pm
Woofster
Canada
Did setting all hot and cold monitoring to NO resolve the brief quick flashing of the turn signals upon initial use?
Post #486098 14th Aug 2018 4:36pm
Yes, as per my post a little way back Thumbs Up
My two issues were:
Message centre messages about tail lights / rear lights
Hyperflash when first using indicators, both sides
Hot monitoring turned off for tail and brake lamps (and front side lights too - have LEDs here)
Hot and Cold monitoring turned off for front and rear indicators, and the side repeaters .
Post #486099 14th Aug 2018 4:54pm
verydisco
I gather your 322 only has the REAR 2009-on lights then, not the front.
This will do the trick indeed then, but if you have the front conversion done, there would be more to it. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #486103 14th Aug 2018 5:49pm
As per thread title: Errors 201-2012 REAR lights Wink .
Post #486107 14th Aug 2018 6:42pm
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Could anyone tell me how I can stop the fog lights coming on with the tail lights as the Powerful UK board causes the latter to flicker slightly when fitted, albeit it seems to solve the fog issue? Thanks.
Post #653692 16th Jan 2023 12:07am
