![]() | Home > Technical (L322) > 5.0 Supercharged niggles. |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3196 ![]() ![]() |
There is a way to initiate one touch windows, not sure what it is. (check wiki for details)
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
open window, pull up on switch and hold to close the window. relise switch and imedietli pull up and hold fo3 3~5 sec.
mcj0rdan Member Since: 27 Aug 2016 Location: Crediton Posts: 18 ![]() ![]() |
Ref windows, I thought great, why didn't I think of that! Driver side worked a treat, but unfortunately, passenger front + both rears will not without holding lift??? |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
Sometimes it takes a couple of goes with the other windows. Drivers window seems to reset first time.
Finally sorted windows! Go through the already stated procedure + lift lever again (window can be seen to rise a further 2/3 mm) one-shot lift working again! Repeat procedure on remaining disobedient windows. |
