Home > Technical (L322) > 5.0 Supercharged niggles. |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
There is a way to initiate one touch windows, not sure what it is. (check wiki for details)
28th Jul 2018 8:24am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
open window, pull up on switch and hold to close the window. relise switch and imedietli pull up and hold fo3 3~5 sec.
28th Jul 2018 8:57am |
mcj0rdan Member Since: 27 Aug 2016 Location: Crediton Posts: 18 |
Ref windows, I thought great, why didn't I think of that! Driver side worked a treat, but unfortunately, passenger front + both rears will not without holding lift??? |
28th Jul 2018 9:49am |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 46 |
Sometimes it takes a couple of goes with the other windows. Drivers window seems to reset first time.
28th Jul 2018 2:39pm |
Finally sorted windows! Go through the already stated procedure + lift lever again (window can be seen to rise a further 2/3 mm) one-shot lift working again! Repeat procedure on remaining disobedient windows. |
28th Jul 2018 5:22pm |
