Home > Technical (L322) > 5.0 Supercharged niggles.
mcj0rdan
Just acquired 5.0 supercharged and luvin it! A couple of niggles, one shot windows up not working (global closing OK). Sometimes a bump or bump bump noise from the rear when pulling away? Doesn't feel like suspension, more like drive. Have heard E Diff can make strange noises?
Any thoughts?
Post #484465 27th Jul 2018 5:03pm
Dolphinboy
There is a way to initiate one touch windows, not sure what it is. (check wiki for details)
Ref rear clunking is possibly rear diff. I would have it checked out and oil changed.
Post #484502 28th Jul 2018 8:24am
nino_nino
open window, pull up on switch and hold to close the window. relise switch and imedietli pull up and hold fo3 3~5 sec.
ripit for all windows. Thumbs Up
Post #484503 28th Jul 2018 8:57am
mcj0rdan
Ref windows, I thought great, why didn't I think of that! Driver side worked a treat, but unfortunately, passenger front + both rears will not without holding lift??? Sad
Post #484506 28th Jul 2018 9:49am
RJDS
Sometimes it takes a couple of goes with the other windows. Drivers window seems to reset first time.
Check for play in the UJ’s, before stripping the diff down. IId etc. Can read remaining life in diff. 2010 TDV8 3.6 Galway Green
Post #484541 28th Jul 2018 2:39pm
mcj0rdan
Finally sorted windows! Go through the already stated procedure + lift lever again (window can be seen to rise a further 2/3 mm) one-shot lift working again! Repeat procedure on remaining disobedient windows. Thumbs Up
Post #484551 28th Jul 2018 5:22pm
