Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 24 of 42 <123 ... 232425 ... 404142>
Range Rover L322
AdamCzix wrote:
Hi, I am currently waiting for smoking machine. Bought one online as might have another use for it. My regen happens automatically but way too often. I have done 150miles trip last week and DPF regen happened 5 times. From approx. 19g back to 2. At some point when driving more aggressively clogging up process was faster than regeneration process. I will post more info when I get my pressure smoke leak detector. At this moment I am trying to calmly drive in town and do one regen trip regulary on M1 to keep car going. The temperature sensor won't change anything, do not bother as its is a pain to change it due to limited access.
Adam I do think it's quite likely you have a leak. Out of interest we don't know what year your car is.
I am guessing it's a late model? 2012?
Post #578763 6th Jan 2021 11:56pm
AdamCzix
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
It is 2011 TDV8 4.4
Post #578764 6th Jan 2021 11:59pm
DrRob
Adam - have you replaced the 4 donut hoses for silicone ones? Flimsy originals often split and let air in. Common issue.
As recommended above, get a HIGH pressure test done by a professional outfit. Intake manifolds can split and only a high pressure test is likely to find it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #578777 7th Jan 2021 10:22am
roel2018
Belgium 2017 Range Rover Autobiography SDV8 Carpathian Grey
How much does a new DPF cost for a 2011 TDV8 4.4? And which part number is that? 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch
Post #580127 17th Jan 2021 4:38pm
Range Rover L322
I think a new DPF is £2,000 ish.
However in the history of this website, I think no-one has ever had one replaced or known anyone to have one replaced with a new one. The DPF itself doesn't go wrong, it's always an ancillary or other part of the system. The DPF itself is a ceramic gauze filter, which works by getting super hot when extra fuel is dumped into it. No moving parts.
I hope that's some help - what problems are you having?
Post #580159 17th Jan 2021 8:23pm
Aman
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Guys I have experienced 2 full dpf red warnings, car went into restricted performance. Turned out to be a faulty erg temperature sensor fault, luckily this sensor is easy to get to. Drove peachy until yesterday due to local short trips the dreaded Red DPF FULL RED returned. Went to my local garage..error code P2463...soot accumulation. Went for a blast to try and regen but nothing..40 mile round trip at high revs using paddle shift. I then bought Wyns DPF cleaner for a tenner..went for a blast again and it's now cleared..car drives beautifully...give it a go before paying someone, also advised to at least once monthly go for a drive a constant high speed for 20mins or so...irritating so to speak, I'm going to avoid diesels going forward..
Post #581237 26th Jan 2021 3:19pm
Aman
Post #581238 26th Jan 2021 3:20pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
How did you manage to clear to red DPF Full message as the car goes into restricted performance when this appears? Would I be right in assuming you have changed the EGR temperature sensor too? 2011 TDV8 Vogue SE
Post #581240 26th Jan 2021 3:28pm
DrRob
Yep, as per owners manual for all to see Thumbs Up
Diesels for long journeys, electric or PHEV for town Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581244 26th Jan 2021 3:40pm
Aman
Hiya yes it was a faulty erg temperature sensor, there are 2, mine failed on the right when looking at the engine...yesterday it did go into restricted performance, so a challenging drive at high revs, car would not exceed 50mph...use a good dpf cleaner as I did..it worked for me..I'll be using a cleaner probably every couple of months...hope this helps...local mechanic with a good reader tool will able to ascertain any error codes..mine also had the engine management light, the light has to be removed prior to attempt a regen Whistle
Post #581245 26th Jan 2021 3:48pm
Range Rover L322
Hi Aman, thanks for this.
So to clarify your garage cleared the fault codes then you took it for a blast and all good?
These particular model (4.4 TDV8) definitely need a regular drive on open road, probably more than any other diesel engined car. Otherwise they will go to Red DPF Full a bit fast.
Post #581256 26th Jan 2021 4:39pm
Aman
Yes fault code will remain until the dpf regent, but before taking it for a good run engine management light needs to be removed, otherwise the ecu will not enable regen...
Post #581259 26th Jan 2021 4:45pm
Graham Nic
Hi, I have a 2011 4.4tdv8 and the new Hawkeye can reset the DPF without having to go to a dealer, done mine a few times and that has paid for the unit a few time over. short runs are the killer though, you need to do at least two miles from cold before stopping, otherwise you are asking for problems.
Post #583115 10th Feb 2021 2:32pm
Baltic Blue
Graham,
I would be very interested if you can reset DPF alarms, particularly if you can check if you have the PO 40D EGR sensor alarm.
The independent garage I have always used is adamant that it is not possible to initiate a forced regen when the sensor is faulty and the fault code PO 40D OO EGR is showing., but I would like to hear of someone having the alarm but able to clear RED DPF warnings.
Post #583118 10th Feb 2021 3:21pm
mrmayhem
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Barolo Black
many thanks for a great and very useful post without which I would never have gone ahead . just to say you can fix this at home as a competent diyer but £250 seems very good value to have it done by a pro .. this is what I did with mine with dpf full red warning .bought icarsoft 2 x 60mm exhaust sleeves cheap exhaust cutter brick cleaner from B&Q total spend £191 with icarsoft to keep when done. cut the after dpf exhaust pipes unbolt the dpf and downpipe 2 rubber pipes for the pressure sensor and 3 sensors, once off bridge the open exhaust pipes, and pressure sensor pipes (small tube for this )I used an old bike inner tube and 2 jubilee clips stand the dpf up against the garage door mix 6 dishwasher tabs in to a bucket of hot water and pour in to the dpf leave to soak for 3 hours .remove inner tube and flush with hose or jet wash refit tube and fill with a mix of 25% brick cleaner and water fill dpf .I left this overnight then gave a good flush with a jet wash in the morning lots of red ash colour water came out keep flushing until clear leave to dry and refit to car . use the Icarsoft and set as new dpf this will clear codes reset ash levels. job done car is now fine. if you can borrow the scanner the job can be done for £60ish
Post #586557 7th Mar 2021 10:19am
