![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
AdamCzix Member Since: 02 Dec 2020 Location: Luton Posts: 13 ![]() ![]() ![]() |
It is 2011 TDV8 4.4 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Adam - have you replaced the 4 donut hoses for silicone ones? Flimsy originals often split and let air in. Common issue.
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 39 ![]() ![]() ![]() |
How much does a new DPF cost for a 2011 TDV8 4.4? And which part number is that? 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
I think a new DPF is £2,000 ish.
Aman Member Since: 26 Jan 2021 Location: West Midlands Posts: 5 ![]() ![]() ![]() |
Guys I have experienced 2 full dpf red warnings, car went into restricted performance. Turned out to be a faulty erg temperature sensor fault, luckily this sensor is easy to get to. Drove peachy until yesterday due to local short trips the dreaded Red DPF FULL RED returned. Went to my local garage..error code P2463...soot accumulation. Went for a blast to try and regen but nothing..40 mile round trip at high revs using paddle shift. I then bought Wyns DPF cleaner for a tenner..went for a blast again and it's now cleared..car drives beautifully...give it a go before paying someone, also advised to at least once monthly go for a drive a constant high speed for 20mins or so...irritating so to speak, I'm going to avoid diesels going forward.. |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
How did you manage to clear to red DPF Full message as the car goes into restricted performance when this appears? Would I be right in assuming you have changed the EGR temperature sensor too? 2011 TDV8 Vogue SE |
Yep, as per owners manual for all to see ![]() Diesels for long journeys, electric or PHEV for town ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Hiya yes it was a faulty erg temperature sensor, there are 2, mine failed on the right when looking at the engine...yesterday it did go into restricted performance, so a challenging drive at high revs, car would not exceed 50mph...use a good dpf cleaner as I did..it worked for me..I'll be using a cleaner probably every couple of months...hope this helps...local mechanic with a good reader tool will able to ascertain any error codes..mine also had the engine management light, the light has to be removed prior to attempt a regen |
Hi Aman, thanks for this.
Yes fault code will remain until the dpf regent, but before taking it for a good run engine management light needs to be removed, otherwise the ecu will not enable regen... |
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 ![]() ![]() |
Hi, I have a 2011 4.4tdv8 and the new Hawkeye can reset the DPF without having to go to a dealer, done mine a few times and that has paid for the unit a few time over. short runs are the killer though, you need to do at least two miles from cold before stopping, otherwise you are asking for problems. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3825 ![]() ![]() ![]() |
Graham,
mrmayhem Member Since: 13 Aug 2018 Location: doncaster Posts: 2 ![]() ![]() ![]() |
many thanks for a great and very useful post without which I would never have gone ahead . just to say you can fix this at home as a competent diyer but £250 seems very good value to have it done by a pro .. this is what I did with mine with dpf full red warning .bought icarsoft 2 x 60mm exhaust sleeves cheap exhaust cutter brick cleaner from B&Q total spend £191 with icarsoft to keep when done. cut the after dpf exhaust pipes unbolt the dpf and downpipe 2 rubber pipes for the pressure sensor and 3 sensors, once off bridge the open exhaust pipes, and pressure sensor pipes (small tube for this )I used an old bike inner tube and 2 jubilee clips stand the dpf up against the garage door mix 6 dishwasher tabs in to a bucket of hot water and pour in to the dpf leave to soak for 3 hours .remove inner tube and flush with hose or jet wash refit tube and fill with a mix of 25% brick cleaner and water fill dpf .I left this overnight then gave a good flush with a jet wash in the morning lots of red ash colour water came out keep flushing until clear leave to dry and refit to car . use the Icarsoft and set as new dpf this will clear codes reset ash levels. job done car is now fine. if you can borrow the scanner the job can be done for £60ish |
