![]() | Home > Technical (L322) > Help! Jumpstarting a 2012 4.4 TDV8 with a DBPOWER Power Bank |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
I forgot to mention that the transmission warning lamp is no longer displayed since I started it again today.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
jumping the battery is the same as replacing one so did you set the steering parameters when you finally got it started...
I did the lock to lock procedure, yes. I've decided to have the battery replaced. I've only owned it for a year and for all I know, it's still the original and the nut on the suspension post you connect the negative jump lead to looked already scratched, suggesting that this wasn't the first time that the battery has been jump started... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
