Home > Technical (L322) > Help! Jumpstarting a 2012 4.4 TDV8 with a DBPOWER Power Bank |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 207 |
Been camping in France all week with my 2012 TDV8 4.4 and after 6 days of locking/unlocking the car and opening/closing the doors the battery is now flat.
6th Jul 2018 8:22pm |
Thanks for the quick reply. Will try that although the instructions tell you to connect the pack and then start car but I'll give it a go.
6th Jul 2018 8:41pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3741 |
Also disable the interior lights by holding the switch for a couple of seconds until the light flashes and then goes out.
6th Jul 2018 8:42pm |
Thanks for the tip. Which switch exactly? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black 2008 Vogue 3.6 TDV8 automatic (LHD), Java Black |
6th Jul 2018 8:45pm |
Switch A.
6th Jul 2018 8:51pm |
Thanks for that, didn't know you could disable the interior lights... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
6th Jul 2018 8:55pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Much more chance of a side effect if you just plug the jump pack in and start!!! Leaving it for 20-30mins allows the battery to charge and to take the strain when you start it... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7894 |
If you have a mains supply - then I'd be inclined to follow Craigs advice to get something into the battery, but then charge the portable pack back up to full and reconnect it before starting the car - every little helps
7th Jul 2018 8:30am |
Thanks for the offer, Alistair, however I'm up in Alpe d'Huez. Got the car started again this afternoon. The power bank above didn't work. The car just drained all its power and still didn't start. We got some jump leads off another camper and after about half an hour with it connected to a friend's car it finally started up. Took it for an hour's drive and it drives ok. However, there are a few problems now:
The rear door electric windows don't work (from any door) The press-and-hold window wind action on the driver's door only works going down but not up. There may be other things I haven't noticed yet. I'm just happy it's running again. Thanks for all your help, people The window symptoms seem similar to when the sunroof issue that can be solved by resetting it. Is there a similar reset routine for the windows? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black 2008 Vogue 3.6 TDV8 automatic (LHD), Java Black |
7th Jul 2018 2:01pm |
I would do a simple battery reset sir... If only to reset the Trans issue |
7th Jul 2018 3:14pm |
I'll leave that until I get home. Don't want to risk meddling now I've got it going. Also, the mirrors no longer fold in and out when locking /unlocking and the car horn (not the alarm) beeps twice when I lock it. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black 2008 Vogue 3.6 TDV8 automatic (LHD), Java Black |
8th Jul 2018 5:41pm |
Frank, imho sir I would do a battery reset now and wouldn’t risk driving a distance with a trans fault showing! Just my opinion sir |
8th Jul 2018 7:32pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Craig,what do you mean by battery reset?Please explain. 2012 TDV8 Vogue SE 4.4 |
8th Jul 2018 8:20pm |
Its all explained in the wiki sir... And will give you more information then i can right now |
8th Jul 2018 10:09pm |
