Home > Technical (L322) > Help! Jumpstarting a 2012 4.4 TDV8 with a DBPOWER Power Bank
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
I forgot to mention that the transmission warning lamp is no longer displayed since I started it again today.
One other thing: I noticed that when you lock the car and after the computer powers down the warning triangle button glows red but the hazard lights are not on. I noticed this the day before the battery died and that it still does now. I'm sure it never used to do this. Does anyone know what this means? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #482916 8th Jul 2018 9:18pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Bow down Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #482931 9th Jul 2018 5:28am
jumping the battery is the same as replacing one so did you set the steering parameters when you finally got it started...
as for the anomolys you have, a proper battery reset as craig suggested would hopefully solve them.. ... - .- -.
Post #482935 9th Jul 2018 7:32am
FrankRizzo
I did the lock to lock procedure, yes. I've decided to have the battery replaced. I've only owned it for a year and for all I know, it's still the original and the nut on the suspension post you connect the negative jump lead to looked already scratched, suggesting that this wasn't the first time that the battery has been jump started... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #482996 9th Jul 2018 4:08pm
