![]() | Home > Technical (L322) > TD6 coolant |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
If the dilution rate is low it will set off sensor also. You might have too weal coolant. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
The dilution or specific gravity has no bearing at all on the sensor. The sensor can be removed from the bottom of the expansion tank without any loss of coolant as it is a magnetic reed switch. If the reed switch tests ok you will need to invest in a new expansion tank, I believe from past experience the magnet on the float becomes weak and gives false alarms. If the reed switch is faulty you can buy a new sensor or just solder in a new 10p reed switch
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Thanks guys.Problem is that before change water pump all were ok.Problem appears when car refilled with new coolant liquid |
Car is 2004 model.Would you please tell me what is the correct cooling liquid.Is it the texaco afc or the havoline xlc or can be used any of them
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Nino many thanks.I will try clean tank during weekend and to be lucky as well
Nino many tks for your advice.Tank washed and floating element became once again floating.
Glad it worked for you to, tks for reporting back. |
