Home > Technical (L322) > TD6 coolant
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
TD6 coolant
Recently in workshop changed the water pump.Genuine Rover coolant used for refilling.
However since then and by the time i start car receive "check cooling liquid" and then notice goes away.
Checking liquid and is within correct levels.
Can it be sudden problem with the sensor or something,by the time they were drying system,stored in memory and now needs to be cleared??
Many thanks for your assistance
Post #482402 2nd Jul 2018 9:38am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
If the dilution rate is low it will set off sensor also. You might have too weal coolant.
Post #482405 2nd Jul 2018 10:10am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The dilution or specific gravity has no bearing at all on the sensor. The sensor can be removed from the bottom of the expansion tank without any loss of coolant as it is a magnetic reed switch. If the reed switch tests ok you will need to invest in a new expansion tank, I believe from past experience the magnet on the float becomes weak and gives false alarms. If the reed switch is faulty you can buy a new sensor or just solder in a new 10p reed switch
https://www.ebay.co.uk/itm/10Pcs-3-20mm-Gl...SwA4BbB8ir 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #482418 2nd Jul 2018 1:31pm
AKIS
Thanks guys.Problem is that before change water pump all were ok.Problem appears when car refilled with new coolant liquid
Post #482423 2nd Jul 2018 2:26pm
AKIS
Car is 2004 model.Would you please tell me what is the correct cooling liquid.Is it the texaco afc or the havoline xlc or can be used any of them
Many tks
Post #482494 3rd Jul 2018 1:18pm
nino_nino
AKIS, most likely is that when the coolant was drained, floating element got stuck on the bottom of the expansion tank, it happened to me. I removed expansion tank out and wash it first with some gasoline and then kitchen degreaser and all is well again. Thumbs Up
Nino,
ps. check this thread:
http://www.fullfatrr.com/forum/topic43284....k+cleaning
Post #482507 3rd Jul 2018 3:47pm
AKIS
Nino many thanks.I will try clean tank during weekend and to be lucky as well
Best rgrds
Post #482600 4th Jul 2018 9:58am
AKIS
Nino many tks for your advice.Tank washed and floating element became once again floating.
All ok now Thumbs Up
Best regards to all
Post #482936 9th Jul 2018 8:15am
nino_nino
Glad it worked for you to, tks for reporting back. Thumbs Up
Nino,
Post #482937 9th Jul 2018 8:42am
