Home > Technical (L405) > Lower tailgate won't close
Page 1 of 3 123>
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Anyone had this?
When I open the tailgate on the fob it opens absolutely fine, fully open upper and lower.
When I try and close it, either with the fob or the buttons on the upper or lower it does not budge. I get a click sound if I press the button on the lower gate, and a light beep if I touch the button on the upper tailgate.
If I close the lower gate manually (which I have to do) the upper will shut on the button.
Any ideas?
Post #481905 26th Jun 2018 3:52pm
Mine has been like it for about 9 months - been meaning to get it looked at, but not got round to it and I’ve learned to live with it - basically have to manually close the lower tailgate every time.
My car is in Bordeaux until late September, so won’t get looked at until at least then.
Hopefully you find a nice simple fix for me Cool
Post #481926 26th Jun 2018 7:39pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
This also started on mine just over a week ago. I will be watching this thread with interest 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #481928 26th Jun 2018 9:24pm
DazzaL405
Australia 2014 Range Rover Vogue TDV6 Indus Silver
Hi everyone
New here but in love with this car!
Mine has just started this weird behaviour too. On the fob won't open fully, hit and miss on the button on the tailgate if it all closes up. Will ask when I service it next.
Post #482388 2nd Jul 2018 1:43am
rob w
mine has also done the same it works fine with the buttons just not with the fob.
Ive had it calibrated with the software and also followed this video .
But still will not work off the fob.
Any one had this fixed?
Rob
Post #484528 28th Jul 2018 2:05pm
pld118
After opening the boot, before trying to close it again, have you tried:
Using the keyfob by pressing the unlock car button before then pressing the keyfob button that is intended for closing the boot (it works every time for me)?
Post #484556 28th Jul 2018 6:57pm
bear100
There is a reset procedure in the manual, it’s worked for me a few times 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #484575 28th Jul 2018 9:51pm
Yes - tried that - the upper starts to close but the lower doesn’t move at all - then the upper returns to its original position
My lower tailgate seems completely dead - press the button and there is a click but no motor noise or movement
It opens fine and can be closed manually. Then the upper part works fine.
Same with the reset procedures etc - they are all about the upper tailgate opening height as far as I can tell.
Post #484596 29th Jul 2018 10:49am
wealy
Got it fixed at Birmingham North Land Rover (Lancaster's) It was a broken wire, fixed under warranty.
Very happy with the service.
Post #491983 12th Oct 2018 4:23pm
Did they tell you which wire ?
It sounds like I have the exact same problem
Mines out of warranty & don't want to spend a fortune on diagnostics Very Happy
Post #491984 12th Oct 2018 4:27pm
wealy
No, it took them about an hour to find it. The fault code was something to do with the anti pinch sensor?
I don't believe it was a broken wire as such, i'm guessing a bad connection??
Post #491987 12th Oct 2018 4:36pm
Thank you Thumbs Up
Post #491997 12th Oct 2018 6:06pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Alistair Did you get this fixed? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #544905 23rd Feb 2020 4:20pm
No - I've just learned to live with closing the lower part manually then pressing the button on the upper.
Post #544906 23rd Feb 2020 4:26pm
horse86
I figured mine out. It was bc the fob was more than 1m away and I was getting a mislock. Kept the fob in my hand standing behind it and it worked fine. Also Figured out it won’t close On the fob with the doors locked. If I hit the unlock on the fob and then then trunk on the fob it closes. So user error for me. Still getting to learn this beast. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #544918 23rd Feb 2020 5:40pm
Page 1 of 3 123>
