Home > Technical (L405) > Lower tailgate won't close
Page 3 of 3 <123
OliverRR91
Hi,
The lower tailgate “loom” connects to the main loom via a horizontal plug in the middle of the car, as you look down when the lower tailgate is open.
My wire was broken in part of the lower tailgate loom where all the wiring is together, not on the fabric part where it’s just the two wires for the sensor.
I also checked continuity with a “beep” holding on the anti pinch sensor pin and touching on each pin on the unplugged main look connector plug. One wire was fine, and the pin next to it is the second wire, which wasn’t fine.
13A444 is the lower tailgate loom if required.
Cheers
Post #665634 1st Jun 2023 1:56pm
Ah - thanks - I only got as far as the 2 wires bit & gave up when it seemed to join a thicker loom.
It's raining now so further investigation is on hold Smile
Post #665637 1st Jun 2023 3:01pm
Well, some progress but no solution yet.
I unravelled the loom & found the break. It was on the external part that sits in-between the tailgate & the wheel well. Soldered it up, tested the continuity & reassembled.
However, it still won't close Big Cry So I cleared the faults & tried again, but still no luck.
The live data is still showing an open circuit on the right anti-pinch sensor. If I swap the connector over and attach the right sensor to the left cable, then it shows the left as open circuit. There is a voltage reading now on the right connector where there wasn't previously.
Conclusion - I need a new sensor too. It seems a huge coincidence - unless something to do with the cable snapping managed to cause the sensor to fail.....
Post #665967 5th Jun 2023 4:49pm
Success !!!!!
My lower pinch sensor arrived on Friday & I fitted it today and my lower tailgate will now close by itself again Very Happy
Thanks to Kot for making me buy a scan tool and diagnosing my own problems from fault codes and especially to OliverRR91 - I don't think I'd ever have got as far as soldering up as broken wiring loom with out your help Bow down
Post #666913 18th Jun 2023 12:34pm
Page 3 of 3 <123
