![]() | Home > Technical (L405) > Lower tailgate won't close |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Anyone had this?
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
This also started on mine just over a week ago. I will be watching this thread with interest 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
DazzaL405 Member Since: 02 Jul 2018 Location: Melbourne Posts: 1 ![]() ![]() ![]() |
Hi everyone
rob w Member Since: 28 Jul 2018 Location: Hartlepool Posts: 2 ![]() ![]() |
mine has also done the same it works fine with the buttons just not with the fob.
After opening the boot, before trying to close it again, have you tried:
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
There is a reset procedure in the manual, it’s worked for me a few times 2010 defender utility
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Yes - tried that - the upper starts to close but the lower doesn’t move at all - then the upper returns to its original position My lower tailgate seems completely dead - press the button and there is a click but no motor noise or movement It opens fine and can be closed manually. Then the upper part works fine. Same with the reset procedures etc - they are all about the upper tailgate opening height as far as I can tell. |
Got it fixed at Birmingham North Land Rover (Lancaster's) It was a broken wire, fixed under warranty.
Did they tell you which wire ?
No, it took them about an hour to find it. The fault code was something to do with the anti pinch sensor?
Thank you |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Alistair Did you get this fixed? 2014 FF Autobiography 5.0 SC
No - I've just learned to live with closing the lower part manually then pressing the button on the upper. |
I figured mine out. It was bc the fob was more than 1m away and I was getting a mislock. Kept the fob in my hand standing behind it and it worked fine. Also Figured out it won’t close On the fob with the doors locked. If I hit the unlock on the fob and then then trunk on the fob it closes. So user error for me. Still getting to learn this beast. 2014 FF Autobiography 5.0 SC
