Home > Maintenance & Mods (L322) > How to tell which rear diff you have? ELectronic or not?
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi, can anyone please tell me how i ascertain which type of rear diff i have fitted to my 2008 TDV8 3.6L322.
Im aware the electronic diff req different oil to the standard one but how to tell so i can drain and refill it. Thanks.
Post #481701 23rd Jun 2018 6:40pm
Ideally get the build sheet
Otherwise, a few clues on this threadl Thumbs Up
Post #481702 23rd Jun 2018 6:51pm
Correct link: http://www.fullfatrr.com/forum/topic29158.html .
Post #481714 23rd Jun 2018 8:17pm
GraemeS
Here's a picture of an e-diff. Note the motor c/w housing on top.
[/img]
Post #481718 23rd Jun 2018 8:48pm
It’s unlikely that someone would spec that as an option while sitting in a dealer. Not impossible but they are as rare and hens teeth on everything but the SC models. It’s pretty obvious when you get under and look at the diff and compare it to the pic above.
Don’t forget to crack the filler before the drain when you do the diff pile swap!! There is nothing that can't be fixed with a hammer😜😜
Post #481720 23rd Jun 2018 10:19pm
dolph34
I thought if you went into the 4 x 4 info display it would show you a picture of a padlock over the rear diff if it was lockable. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481721 23rd Jun 2018 11:09pm
GraemeS
Only if it turns red in slippery conditions.
Post #481722 24th Jun 2018 2:58am
Rapiscan
Thanks everyone for your inputs, on closer inspection my diff does seem to have a wire going in the top and the casing has lumps n bumps I wouldn’t associate with an ordinary diff so I’m inclined to think it’s an e diff requiring oil dearer than Dom Perignon champers Shocked Someone has said ALL rangies after 2007 have ediffs? True or false?
Post #481731 24th Jun 2018 8:21am
nino_nino
false.
Post #481732 24th Jun 2018 8:43am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Advanced Factors list this one for the ediff which isn't that much more expensive than the standard stuff.
https://www.advancedfactors.co.uk/adv909-1...8277-p.asp 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #481733 24th Jun 2018 9:08am
GraemeS
This is the standard open diff.
Post #481734 24th Jun 2018 9:38am
mjdronfield
Isn’t there something different on the 4x4 info display on the screen if there is a rear e diff? Might be wrong....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #481738 24th Jun 2018 10:07am
bishbosh10
I think it is a bit daft on the 4x4 info screen to show a padlock at all on a diff that is not lockable! I know mine is not an e diff but I still get a stoopid green padlock when in the relevant off road mode. Censored Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #481796 24th Jun 2018 8:04pm
GraemeS
IIRC D4s originally had the same sillyness but some time later the display software was changed to only show the padlock if the e-diff is fitted.
Post #481801 24th Jun 2018 8:44pm
Kiwimac
New Zealand 2006 Range Rover Supercharged 4.2 SC V8 Java Black
My Discovery 3 had the locking rear diff and the 4x4 info screen showed the padlock all the time, only turned green if the system locked the diff.
My FFRR SC 4.2 does not (appear) to have the locking diff, at least the padlock is not shown on the 4x4 info screen.
Post #481950 27th Jun 2018 3:20am
