![]() | Home > Maintenance & Mods (L322) > How to tell which rear diff you have? ELectronic or not? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Ideally get the build sheet
Correct link: http://www.fullfatrr.com/forum/topic29158.html .
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
Here's a picture of an e-diff. Note the motor c/w housing on top.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
It’s unlikely that someone would spec that as an option while sitting in a dealer. Not impossible but they are as rare and hens teeth on everything but the SC models. It’s pretty obvious when you get under and look at the diff and compare it to the pic above.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I thought if you went into the 4 x 4 info display it would show you a picture of a padlock over the rear diff if it was lockable. 2015 4.4 AB
Only if it turns red in slippery conditions. |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Thanks everyone for your inputs, on closer inspection my diff does seem to have a wire going in the top and the casing has lumps n bumps I wouldn’t associate with an ordinary diff so I’m inclined to think it’s an e diff requiring oil dearer than Dom Perignon champers |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
false. |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Advanced Factors list this one for the ediff which isn't that much more expensive than the standard stuff.
This is the standard open diff.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Isn’t there something different on the 4x4 info display on the screen if there is a rear e diff? Might be wrong....
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I think it is a bit daft on the 4x4 info screen to show a padlock at all on a diff that is not lockable! I know mine is not an e diff but I still get a stoopid green padlock when in the relevant off road mode. |
IIRC D4s originally had the same sillyness but some time later the display software was changed to only show the padlock if the e-diff is fitted. |
Kiwimac Member Since: 15 Jun 2018 Location: Wellington Posts: 48 ![]() ![]() ![]() |
My Discovery 3 had the locking rear diff and the 4x4 info screen showed the padlock all the time, only turned green if the system locked the diff.
