![]() | Home > Maintenance & Mods (L322) > Gearbox oil again |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 ![]() ![]() ![]() |
https://www.lrparts.net/vehicle/range-rove...-oils.html
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Only use ZF Lifeguard Fluid 6 in your 6HP26 transmission
Nelly Member Since: 02 May 2018 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Cheers for that guys, it's appreciated.
So, spoke with a gearbox specialists who said that he always replaces the sump pan with a steel one with separate filter, as they break and you have to jack the engine up slightly to get the pan off and back on.
If you had a Disco 3, Disco 4 or RRS with the crossmember getting in the way then, fair enough, you might want to swap over to the metal sump to make future filter changes easier. On an L322, though, it’s pointless. Won’t do any harm, just totally unnecessary.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
As Phil says, you don't need to use the metal sump on a FFRR, access is easy - there is no crossmember in the way.
That's why I ask,
