Home > Maintenance & Mods (L322) > Gearbox oil again
Nelly
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Gearbox oil again
Guys,
Can I have some help pls, I have read through wiki and I'm a bit confused
Going to change the gearbox oil on my TDV8 2008 and want some advice
So, no to mega flush, empty oil, refill and empty, then refill again?
What oil?
Any other bits I will need, filter ect
Cheers 2007 range rover vogue, Black with issues
Yamaha raptor Gsxr 1000
Yamaha raptor 700
Audi A6 Black edition
Fully restored Vespa px125
Post #480145 4th Jun 2018 8:19pm
lazylabs
https://www.lrparts.net/vehicle/range-rove...-oils.html
Best to Megaflush really because by the time you have drained, refilled, drained and refilled again you will be at the price of a Megaflush and yet you still won't of changed 100% of oil..
However the above link is where I have got my oil and sumps etc from in the past.. Current Family:
2012 FFRR 4.4 TDV8 Westminster
2013 Jaguar XFs 3.0d Sportbrake
2008 FFRR 3.6 TDV8 VSE (Gone)
2008 Ford Mondeo mk4 2.2tdci (Gone)
2006 S Class 320 CDI (Gone)
1998 P38a 4.6 VSE Oxford Blue 98k (Gone)
Vx Vectra C Estate 1.9cdti 150 (with a few twists) (Gone)
Other LR's in Family (2019 4.4 TDV8 AB)
Post #480162 4th Jun 2018 10:50pm
RRPhil
Only use ZF Lifeguard Fluid 6 in your 6HP26 transmission
and a genuine IBS Filtran filter/sump pan
If your mechatronic sealing sleeve still has the old orange seals, which are prone to leak, it’s a good opportunity to replace this with the latest (black seal) version while the sump is off.
Phil
Post #480164 4th Jun 2018 11:51pm
Nelly
Cheers for that guys, it's appreciated.
My mate has his own garage and will let me use a ramp at the weekend, so it looks like an easy job, is that correct. (I am preety good with a spanner)
Many thanks 2007 range rover vogue, Black with issues
Yamaha raptor 700
Post #480264 5th Jun 2018 9:42pm
Nelly
So, spoke with a gearbox specialists who said that he always replaces the sump pan with a steel one with separate filter, as they break and you have to jack the engine up slightly to get the pan off and back on.
All in with the correct oil and new sump £400.00
What do you guys think,about right or talking ****
Yamaha raptor 700
Post #481614 22nd Jun 2018 11:59am
RRPhil
If you had a Disco 3, Disco 4 or RRS with the crossmember getting in the way then, fair enough, you might want to swap over to the metal sump to make future filter changes easier. On an L322, though, it’s pointless. Won’t do any harm, just totally unnecessary.
Phil
Post #481616 22nd Jun 2018 1:00pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
As Phil says, you don't need to use the metal sump on a FFRR, access is easy - there is no crossmember in the way.
From my recent experience, you can get out 6.5 litres from the 6 speed g.box, during a normal empty & re-fill.
I didn't think a megaflush was worth on it on that basis. Then the cost is approx £140 for the correct ZF fluid & £60 for the plastic sump pan / filter if you're swopping the filter as well. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #481618 22nd Jun 2018 2:11pm
Nelly
That's why I ask,
Will do that, get the zf oil new pan and plug from my local LR indy specialist and do it in my mates Garage
Cheers all 2007 range rover vogue, Black with issues
Yamaha raptor 700
Post #481620 22nd Jun 2018 3:02pm
