Home > Maintenance & Mods (L322) > Replacing shock absorbers on 2011 4.4
Peters52
England 2011 Range Rover Vogue SE 4.4 V8 Barolo Black
Hi, Just looking for a little advice - I am about to replace the rear shocks on my 2011 4.4 V8. They are separate from the air springs, yet the manual I have indicates that the air system should be depressurised before removing the shock. Any ideas why that would be? I wouldn't normally remove or compress a spring to remove a shock, why on the RR?
Hope someone can shed light on this
Post #478686 17th May 2018 2:21pm
can't see the point, they bolt on, and are no where near the springs.
Just out of interest why are you changing them? mine have been weeping ever so slightly for a while now and never really been a problem. There is nothing that can't be fixed with a hammer😜😜
Post #478693 17th May 2018 4:10pm
Paul thornton
It's in case you let the axle drop as you will tear the rubber spring. Just make sure you support it and it should be fine.
Post #478697 17th May 2018 4:44pm
Peters52
Many thanks, it’s a relief to get a second opinion. I’m changing them because they came up as an advisory on the MOT and the car feels ‘bouncy’ at the back - hope this does the trick as they ain’t cheap!
Post #478992 20th May 2018 7:53pm
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
how much $$,
Post #479015 21st May 2018 7:58am
