![]() | Home > Maintenance & Mods (L322) > Replacing shock absorbers on 2011 4.4 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
can't see the point, they bolt on, and are no where near the springs.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
It's in case you let the axle drop as you will tear the rubber spring. Just make sure you support it and it should be fine. |
Peters52 Member Since: 06 May 2018 Location: County Durham Posts: 5 ![]() ![]() ![]() |
Many thanks, it’s a relief to get a second opinion. I’m changing them because they came up as an advisory on the MOT and the car feels ‘bouncy’ at the back - hope this does the trick as they ain’t cheap! |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
