![]() | Home > Technical (L405) > 3.0 TDV6 L405 - Cambelt, Tools, Cost - 7yrs / 112k miles |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 243 ![]() ![]() |
From what I recall it's 7years of 112k miles
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
if its as easy as the 3.0 tdv6 disco then 800 quid is way more than it should cost |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
if its the same as the 2.7 then its not..... there are 2 belts on the 2.7 and the rear one is a PITA to do. Not sure if they got rid of this on the 3.0 though? mine was done as part of the 7 year service on the disco last year.
Thanks for the replies, it was a 'false start' thanks to the Farnell generic service booking call centre.
The L405 3.0 TDv6 cam belt (or timing belt) should be changed - according to LR schedules - at 7 years or 112,000 miles, whichever is first.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2638 ![]() ![]() |
The rear belt on the 3.0 D4 has worse access than the 2.7 due to extra pipework and other brackets and that the 3.0's HP pump has to be timed, unlike the 2.7, but perhaps there's more room behind the L405's engine. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
But there is sooooo much room at the front |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
If that’s the price for just the cam belt? It’s to expensive. If it’s for both the cam belt and the pump belt that’s at the rear of the engine? It’s cheap ish.
I've seen the rear belts break up on the 2.7, eating their way through the belt cover, then tearing through wiring looms...
MD costs vary considerably to change the L405 3.0 TDv6 cambelt. It should be changed at 7 yrs / 112,000 miles.
Is that front belt only, or rear belt too?
Don't know the detail on this yet Mikey... Will find out tomorrow and update.
Now being told that quotes given were in accordance with LR MD "fixed price servicing" and that yes, there are two belts, but the quotes only cover replacing one belt! Well that's what one MD is saying, another is admitting it's a kit and they've no idea.
