Home > Technical (L405) > 3.0 TDV6 L405 - Cambelt, Tools, Cost - 7yrs / 112k miles
Page 2 of 3 <123>
Mikey
Strictly speaking, 3 belts
Cambelt
HPFP belt
Aux belt
Whistle Thumbs Up
Aux belt needs removed to replace the front belt
Sounds like that's what is being quoted for, and no mention of the HPFP belt
Post #545817 2nd Mar 2020 9:00pm
pld118
The service advisors have no idea what is being quoted for. I’ve spoken to 5 of them now at different garages and not one of them has had a scooby doo what they’re on about.
Post #545819 2nd Mar 2020 9:07pm
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
I rang round various md’s and indy’s last year before I purchased the l405. Only because I owned a disco tdv6 many moons ago when they was quoting £1000 + for belt changes. At the time neither the md’s or indy’s had a clue how to price the job. It was as if the l405 was to new. Literally no one had a clue.
Now the l405’s are getting higher up in mileage I’ve noticed more and more posts about it. The cam belt really is no different on the 3.0 l405 than it was on the older tdv6’s so that price should be no different. I honestly think anyone mechanically minded could do this diy. The rear belt on the other hand being timed would be a whole new story.
I shouldn’t feel like it. But Unless you know the garage well, how would you ever know if this work had been done? I did get in contact with an Indy last year that actually sounded like they knew what they was talking about. Also said they hadn’t done a belt change on the new 3.0 but seemed to know there stuff. From memory the price was around £700 for both belts.
Post #545823 2nd Mar 2020 9:34pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
very good point - applies to anything you cant see inc gearbox, diff, transfer oils etc
Post #545853 3rd Mar 2020 9:43am
GraemeS
Australia
Timing the fuel pump belt is well documented in the workshop manual and less technically challenging than changing the camshaft belt which if mistimed can damage valves and pistons rather than just the fuel pump not correctly providing fuel. I found that access on a 3.0 D4 to get the fuel pump timing correct was difficult but checking that the timing was correct before activating the tensioner was not difficult - I did it over and over by feel until I managed to get the timing correct.
Post #545878 3rd Mar 2020 12:34pm
pld118
Had a telephone quote from an independent LR Specialist today: £985 incl VAT
That price was for genuine LR parts - he said price includes fan belt, cam belt, fuel pump belt, idle pulleys and coolant as they tend to replace the coolant whislt doing it (if I've remembered it all correctly).
As mentioned, ours hasn't hit the replacement threshold yet despite what an LR MD Service Advisor said... but worth forward planning for, especially if that's a realistic price.
Post #545897 3rd Mar 2020 6:44pm
Felstmiester
so is there locking tools used for rear belt? I’ve heard of people cutting the old belt around the middle to slip the new one on. How much shorter is the fuel pump belt?
Post #546158 6th Mar 2020 9:17am
Mikey
There is a special tool required to lock to HPFP in its timed position, as well as the camshaft locking tool Thumbs Up
Post #546193 6th Mar 2020 2:38pm
Felstmiester
Also. Is it important to change the oil pump on these while your at it?
Post #547118 14th Mar 2020 1:41pm
pld118
I’ve spoken to an LR independent specialist and about 4 LR main dealers for quotes. Most of the main dealer service advisors didn’t seem to know what they were taking about (didn’t explain at all well what the work would entail and had to go and ask when I mentioned a second belt).
The only person who volunteered changing 3 belts at once (the ones I mentioned in an earlier post) was the independent.
None of them mentioned changing an oil pump.
The specialist’s quote was dearer than the quotes offered by main dealers albeit he was very specific about what the work entailed. I’m not really sure what the going rate to change the 3 belts is at this time and am trying to get some clarity.
I’d rather get ours done by “a reputable independent” because I’ve little confidence in main dealers (for good reason over years experience) but... I’m wary because of the LR Extended Warranty and the fear of them trying to dodge a claim if something associated to the cam belt change goes awry in the future (£145.50/ month for so called “peace of mind”, therefore I’ve a right to be wary).
Post #547119 14th Mar 2020 1:54pm
Mikey
Oil pump isn't an issue on the 3.0 engines Thumbs Up
I've quoted L405/494 belts at £450 + VAT, for all 3 belts, using all OEM parts. Not sure how that compares to any other quotes you've had, but that's where I am
Provided the belt has been replaced by a VAT registered garage, using OEM quality parts, extended warranty should not* reject a claim Thumbs Up
* I'd have said cannot, but with warranty companies, you never know Rolling Eyes
Post #547129 14th Mar 2020 3:17pm
pld118
Thanks Mikey,
The “LR warranty company” said the parts must be genuine LR so is that different to what you mean by OEM parts?
I ask because the specialist who quoted £985 started off quoting a price for a make that I think started with a letter D and which he said was exactly “the same make as LR” but then when I asked if it was LR branded (to comply with the warranty) he said he’d need to get me another price... and it ended up dearer at £985
Post #547151 14th Mar 2020 5:35pm
Mikey
Dayco, which are OEM, and exactly the same parts and quality you'd get from an LR dealer, minus the LR box (and price!)...
I've never heard of a warranty company stipulate that genuine LR parts must be fitted though, and we do work for LRA Approved (Car Care Plan) warranty, Warranty Direct, Scotsure etc...
If genuine LR parts MUST be fitted, that would increase the price somewhat, but not to £985...
Post #547156 14th Mar 2020 6:40pm
Felstmiester
do u travel to Essex anytime? Lol
Post #547160 14th Mar 2020 6:52pm
Mikey
No, but I've had customers travel from Essex up to me Laughing
Post #547167 14th Mar 2020 7:28pm
Page 2 of 3 <123>
