Home > Maintenance & Mods (L322) > Brakes, to grease or not to grease, that is the quesation
Webbie
I am fitting new rear pads and disks.
Should we no longer apply copper grease to the back of the pads?
Should I apply CeraTec to the back of the pads instead?
Or, Should the back be left dry?
If left dry, will they sequel?
Thanks in advance for your thoughts, hopefully they will all concur and not conflict Wink
Post #475086 7th Apr 2018 9:58am
this is what it says in the WM so i would say yes..
Post #475090 7th Apr 2018 10:07am
Pawl
Mating surfaces means where the pads slide in the caliper NOT between the pad & piston(s) .
The antisqueal layer on the back of the pads works by sticking to the piston, so that the pad can't vibrate (squeal) so easily because the of the extra weight & support the piston(s) provide Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #475094 7th Apr 2018 10:39am
ah, that makes sense Thumbs Up
i think i would still put a bit of grease on the back of the pads to help reduce the probability of squealing .. ... - .- -.
Post #475098 7th Apr 2018 10:56am
Pawl
Don't add grease to the back of the pads - it does nothing positive !
It means the anti-squeal material can't work to stick the pad backplate & piston together & is actually then only a negative because the material is compressible & is adding extra pedal travel at higher pedal forces.
Note the WM does not mention pistons.
The vehicle & brake manufacturers accept the small increase in pedal travel as an acceptable compromise if they can stop squealing. If you're going to grease, you may as well slice off the anti-squeal material. Paul,
Post #475110 7th Apr 2018 11:29am
Pawl
It's worth adding that NO vehicle OR brake manufacturer uses grease between the pads & pistons to stop squeal.
It's just an old wives tale, based on misunderstanding instructions about where to use grease Paul,
Post #475111 7th Apr 2018 11:32am
Rob99
I've just replaced all my brakes and the WM gives very specific instructions about applying grease to the areas on the back of the pads that are in contact with the pistons. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #475141 7th Apr 2018 3:52pm
Webbie
Thanks for all the reply’s, if only I had the relevant page of the workshop manual.
Post #475145 7th Apr 2018 4:20pm
Baltic Blue
Q.E.D.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #475146 7th Apr 2018 4:25pm
Pawl
I'm very surprised if the Land Rover manual suggests using grease between pads & pistons.
The electronic 2006 ~ 2010 Land Rover Workshop Manual I use makes no mention of grease being used at all to reassemble / replace pads.
I can also see no reference to grease in the 2002 ~ 2006 manual either - but that manual doesn't provide very much good info generally. Paul,
Post #475148 7th Apr 2018 5:22pm
pld118
So where do you put the grease then?
Post #475150 7th Apr 2018 5:32pm
Rob99
The page that Baltic Blue posted is from the 2010-2012 WM 2021 D350 Fifty Edition - Carpathian Grey
Post #475152 7th Apr 2018 5:56pm
Pawl
I'm busy looking for a hat to eat - lol. Embarassed
In 30 years of working in the UKs only brake manufacturer, I've never seen a manufacturer specify greasing like that.
I can only think there's something odd about the way the 6 pot Brembo callipers work that means grease helps.
Question for anyone with the 6 pot callipers - is there any material on the back of the brembo pads or is it just metal ?
BTW : For anyone intrigued enough , the usual reason to get the piston & pads to stick together when under pressure is that the increased mass of the combination reduces the natural frequency of the sound when they vibrate, in an attempt to eliminate or change any squealing noises. Paul,
Post #475159 7th Apr 2018 7:28pm
nino_nino
+1
Post #475170 7th Apr 2018 9:26pm
Rob99
Pawl wrote:
Question for anyone with the 6 pot callipers - is there any material on the back of the brembo pads or is it just metal.
The new genuine pads I've just put on the front (6 pot brembo calipers) had a sticky adhesive layer on the back of each pad too. 2021 D350 Fifty Edition - Carpathian Grey
Post #475191 8th Apr 2018 8:23am
