Home > In Car Electronics (L322) > Help - MOST Connector
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I purchased an audio connectivity module (VPLME0004) on eBay, as new but it had been opened.
Now I've come to fit it, and with the car in bits, I've discovered it's missing one of the MOST connectors - just the "adapter" part that the end of the "B" cable plugs into (highlighted below)
When I do an Ebay search I get back a lot of loop connectors such as this https://www.ebay.co.uk/itm/fiber-optic-loo...2544689488
Would that do the job or am I barking up the wrong tree (as well as contacting the Ebay seller that sold me the module in the hope he still has the part)?
Even better is this the sort of thing any bricks and mortar shop might stock so I can get the dashboard back together.... 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #473627 23rd Mar 2018 5:55pm
if thats a fibre optic connector you are after you could strip the cable and use a piece of biro to bridge the signal.. ... - .- -.
Post #473628 23rd Mar 2018 6:00pm
MikeO
Thanks stan. Do you happen to have a link to any more details? I've never heard of doing that. It is just two pairs of fibre optic cables. One pair is plugged into a male adapter and the other a female to keep them nearly butted against one another. It's the female adapter that's missing... 2016 Skoda Octavia VRS Estate
Post #473632 23rd Mar 2018 6:42pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
If you have the optic leads and are just missing the female connector bit, you should be able to buy a MOST loop and dissassemble it to give you just the shell of the connector.
Then plug the two optics from the kit into it et viola.
I did the reverse to create a MOST loop to remove the CD changer from my audio connectivity module when I had issues.
Post #473638 23rd Mar 2018 7:15pm
MikeO
That was what I was thinking but wanted someone who'd actually done something with MOST connectors to confirm. Sounds like it might just work. Thanks! 2016 Skoda Octavia VRS Estate
Post #473642 23rd Mar 2018 7:49pm
Jamiehol
No worries, generally there is a little blue thing in the centre of the connector that you need to remove to get the optic leads out.
Post #473645 23rd Mar 2018 7:55pm
MikeO
Thanks for the advice. I managed to cludge something together using a small plastic offcut to create a channel to keep them aligned. Some double sided tape in there and wrapping it with a bit of electrical tape to keep it all together. It's working as a temporary measure until the connectors turn up at least. 2016 Skoda Octavia VRS Estate
Post #473760 24th Mar 2018 10:25pm
