Home > In Car Electronics (L322) > Help - MOST Connector |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
I purchased an audio connectivity module (VPLME0004) on eBay, as new but it had been opened.
23rd Mar 2018 5:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35336 |
if thats a fibre optic connector you are after you could strip the cable and use a piece of biro to bridge the signal.. ... - .- -.
23rd Mar 2018 6:00pm |
Thanks stan. Do you happen to have a link to any more details? I've never heard of doing that. It is just two pairs of fibre optic cables. One pair is plugged into a male adapter and the other a female to keep them nearly butted against one another. It's the female adapter that's missing... 2016 Skoda Octavia VRS Estate
23rd Mar 2018 6:42pm |
That was what I was thinking but wanted someone who'd actually done something with MOST connectors to confirm. Sounds like it might just work. Thanks! 2016 Skoda Octavia VRS Estate
23rd Mar 2018 7:49pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
No worries, generally there is a little blue thing in the centre of the connector that you need to remove to get the optic leads out. |
23rd Mar 2018 7:55pm |
Thanks for the advice. I managed to cludge something together using a small plastic offcut to create a channel to keep them aligned. Some double sided tape in there and wrapping it with a bit of electrical tape to keep it all together. It's working as a temporary measure until the connectors turn up at least. 2016 Skoda Octavia VRS Estate
24th Mar 2018 10:25pm |
