![]() | Home > Technical (L322) > Power steering stiff |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
I have similar symptoms on our 2006 TDV8. From what I've found, it could either the bcu or the servotronic valve. Now the weather is getting slightly warmer I'm going to test the signal at the servotronic valve & see whether I can work out which is the problem.
I couldn't find a way of testing the electronic signals between the BCU & Servotronic valve on the steering rack, so bit the bullet & decided to fit a replacement servotronic unit to our TDV8 with heavy steering.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
that little filter is defo problematic...i left the old one in and the job was much easier.. ... - .- -.
Stan,
that was bad luck, mine was conveniently stuck .. ... - .- -.
ammar Member Since: 10 Jun 2018 Location: Bedford Posts: 9 ![]() ![]() ![]() |
Hi all,
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Sounds like the seals in the rack are leaking. New or recon rack Chap. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
thanks, will get it checked. much appreciated for the help. |
hi guys,
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Currently open on another tab in my browser.......
Thanks for the help everyone. Much appreciated, my mechanic found one from local part shop with 12 months warrant, similar in price. |
Hi Guys,
Hi All,
I've just looked at the process to change the rack and it doesn't look short - RAVE (downloadable from the wiki - workshop service manual) says you have to remove the sub frame. I was eyeing it up thining you might be able to twist the rack out without doing so. I'd say 4hrs+, I think that you can look up how long a job takes somewhere in RAVE nut I don't know
