Home > General > Number plate size |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1726 |
Hi Folks
21st Jan 2011 8:58am |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
they are standard uk size front and rear |
21st Jan 2011 9:01am |
dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014 |
They are "normal" but it depends what size you have on there already. They all seem to vary by half an inch or so. I've never found two "standard" sized plates the same.
21st Jan 2011 9:08am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
when i brought mine it had a larger one on the back to fit the large space but i had a new one done to normal specs which does look better... |
21st Jan 2011 10:17am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
You see, I prefer the larger rear plates, I think it finishes the car off...
21st Jan 2011 2:17pm |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 |
I have the larger one.
21st Jan 2011 2:19pm |
large number plate.......large nose?. here's mine....
21st Jan 2011 2:31pm |
3 strips of 1mm sticky pads, the same as the front one.
21st Jan 2011 4:51pm |
You measured? 15MY SDV8 Vogue SE |
21st Jan 2011 4:54pm |
The FFRR has a larger than standard plate on the rear. |
21st Jan 2011 4:55pm |
No, I just read the box in Halfords that said, "1mm double sided number plate fixing pads" 2006 Mercedes CLS
21st Jan 2011 4:56pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
I've just been converted..
5th Feb 2011 6:49pm |
