Home > General > Number plate size
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Number plate size
Hi Folks
Just about to oder som enew plates to be made up for the car (all road legal etc) but just wanted to check that they are the same size (front and back) as "normal" car plates. My P38 had a bigger than normal plate but son't want to mess up.
Could youplease confirm they are just normal size now.
Thanks Ash
2016 SDV8 AB
Post #46850 21st Jan 2011 8:58am
tommac22
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
they are standard uk size front and rear
Post #46851 21st Jan 2011 9:01am
dan_uk_1984
They are "normal" but it depends what size you have on there already. They all seem to vary by half an inch or so. I've never found two "standard" sized plates the same.
The P38 could have whatever sized plates you want as it just bolted onto a flat surface front & rear, again just depends what was fitted previously.
Post #46852 21st Jan 2011 9:08am
when i brought mine it had a larger one on the back to fit the large space but i had a new one done to normal specs which does look better...
Post #46855 21st Jan 2011 10:17am
M44K TS
You see, I prefer the larger rear plates, I think it finishes the car off...
Standard size
Larger size (53.5cm wide and 15cm high)
 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #46890 21st Jan 2011 2:17pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I have the larger one.
And you know what they say...........? 15MY SDV8 Vogue SE
Post #46891 21st Jan 2011 2:19pm
large number plate.......large nose?. Very Happy
here's mine....
Post #46897 21st Jan 2011 2:31pm
Jem0911
No.
Large number plate?........
More double sided sticky tape!!! 15MY SDV8 Vogue SE
Post #46902 21st Jan 2011 2:42pm
M44K TS
3 strips of 1mm sticky pads, the same as the front one.
Your logic is flawed Laughing 2006 Mercedes CLS
Post #46914 21st Jan 2011 4:51pm
Jem0911
You measured? 15MY SDV8 Vogue SE
Post #46916 21st Jan 2011 4:54pm
The FFRR has a larger than standard plate on the rear.
Post #46917 21st Jan 2011 4:55pm
M44K TS
No, I just read the box in Halfords that said, "1mm double sided number plate fixing pads" Laughing 2006 Mercedes CLS
Post #46918 21st Jan 2011 4:56pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
I've just been converted..
£18 delivered next day.
Post #49003 5th Feb 2011 6:49pm
