![]() | Home > General > Number plate size |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1748 ![]() ![]() ![]() |
Hi Folks
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 ![]() ![]() ![]() |
they are standard uk size front and rear |
They are "normal" but it depends what size you have on there already. They all seem to vary by half an inch or so. I've never found two "standard" sized plates the same.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
when i brought mine it had a larger one on the back to fit the large space but i had a new one done to normal specs which does look better... |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
You see, I prefer the larger rear plates, I think it finishes the car off...
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
I have the larger one.
large number plate.......large nose?. ![]() here's mine....
3 strips of 1mm sticky pads, the same as the front one.
You measured? 15MY SDV8 Vogue SE |
The FFRR has a larger than standard plate on the rear. |
No, I just read the box in Halfords that said, "1mm double sided number plate fixing pads" |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
I've just been converted..
