![]() | Home > Maintenance & Mods (L322) > Lambda Sensors |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
The plastic pipe is a vent tube for the front differential. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
also have you checked the oil pan for plastic bits ? sounds like metal on metal can could be worse case timing guides where the chains starts hitting metal.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Not checked yet hoping it’s not and sounds different to the other vids I’ve heard of bad guides the noise is coming from close to the water pump going to check it for wobble first as it could be that? Current stable:
this video was when i caught my timing chain issue early. one guide had failed and others were falling apart.
Great I shall have a listen - I should add that the same day it started the coolant warning came on and I was a fair bit of fluid down so hoping it’s pointing that way! Current stable:
hope its a simple water pump its alot cheaper fix |
Yea me too how many miles had you done before the guides went? Had you ever changed your external tensioner? When I got mine the chain sounded really sloppy so I did the external tensioner and it sounded tight again I wonder if this sometimes gets overlooked and the sloppyness causes the guides to smash apart. Seem to be a mix of
the guides went around 90k Miles which is very low.. but was told its more to do with the age of the plastic inside the engine mine car was around 13years old at point the guide faile and the car has had excellent service history. and very well looked after in my owner ship ( http://www.fullfatrr.com/forum/topic39687.html )
Hmm it hardly sounds like any but the 3rd one is closest I will fire her up tomorrow with an ear out Current stable:
So I’m impatient
that water pump is on its way out as it should not move like that |
Sweet I’m hoping it makes it to the shop and back (10 mile round trip) as that’s all I have to get parts with... at least I have aa Current stable:
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Yep that pump is goosed.
Really I bought genuine so hoping it doesn’t 4x the price of euro Current stable:
