Home > Maintenance & Mods (L322) > Lambda Sensors
Page 2 of 3 <123>
Danwilderspin
bump...
also anyone able to tell me if that plastic pipe is normal in the picture I posted its not connected to anything? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473224 20th Mar 2018 7:22pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
The plastic pipe is a vent tube for the front differential. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #473318 21st Mar 2018 2:46pm
b348xyx
also have you checked the oil pan for plastic bits ? sounds like metal on metal can could be worse case timing guides where the chains starts hitting metal.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #473319 21st Mar 2018 2:48pm
Danwilderspin
Not checked yet hoping it’s not and sounds different to the other vids I’ve heard of bad guides the noise is coming from close to the water pump going to check it for wobble first as it could be that? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473320 21st Mar 2018 2:49pm
b348xyx
this video was when i caught my timing chain issue early. one guide had failed and others were falling apart.
of course mine was all replaced.
This video is when my timing guide began failing coming apart :
There two videos below was when my water pump began to fail, was replaced by LR specialist. it wasn't leaking but had some wobble.
hope this may help. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #473321 21st Mar 2018 3:05pm
Danwilderspin
Great I shall have a listen - I should add that the same day it started the coolant warning came on and I was a fair bit of fluid down so hoping it’s pointing that way! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473322 21st Mar 2018 3:07pm
b348xyx
hope its a simple water pump its alot cheaper fix Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #473323 21st Mar 2018 3:08pm
Danwilderspin
Yea me too how many miles had you done before the guides went? Had you ever changed your external tensioner? When I got mine the chain sounded really sloppy so I did the external tensioner and it sounded tight again I wonder if this sometimes gets overlooked and the sloppyness causes the guides to smash apart. Seem to be a mix of
Failure mileage’s and some 200k + still going strong Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473325 21st Mar 2018 3:11pm
b348xyx
the guides went around 90k Miles which is very low.. but was told its more to do with the age of the plastic inside the engine mine car was around 13years old at point the guide faile and the car has had excellent service history. and very well looked after in my owner ship ( http://www.fullfatrr.com/forum/topic39687.html )
I believe you are correct the old chain tensionor spring was very soft and could have been this aswell and well it could have certainty been one of the issues when chain slapping about and hitting the hardened plastic. i feel i was just unlucky.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #473326 21st Mar 2018 3:17pm
Danwilderspin
Hmm it hardly sounds like any but the 3rd one is closest I will fire her up tomorrow with an ear out Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473367 21st Mar 2018 10:10pm
Danwilderspin
So I’m impatient
I wobble the viscous fan belt on and watch the pulley - guessing it shouldn’t move like that - bad pump?
Here’s the best noise but it from in front of grill so bad pic
On a side note your video that was the chain guides I have heard that I can’t remember if it was this Range Rover before the tensioner or my e39 m5 I think the m5 and I just lived with it it never got worse though strange Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473373 21st Mar 2018 11:04pm
b348xyx
that water pump is on its way out as it should not move like that Smile hopefully that will fix your noise 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #473391 22nd Mar 2018 9:06am
Danwilderspin
Sweet I’m hoping it makes it to the shop and back (10 mile round trip) as that’s all I have to get parts with... at least I have aa Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473395 22nd Mar 2018 9:31am
Rewmer
Yep that pump is goosed.
Hope you have better luck than me with the waterpump. I fitted a good OEM unit only to have it spring a leak from a dodgy casting two weeks after fitting. No7 - 2003 V8 Vogue
Post #473456 22nd Mar 2018 6:12pm
Danwilderspin
Really I bought genuine so hoping it doesn’t 4x the price of euro Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #473457 22nd Mar 2018 6:15pm
Page 2 of 3 <123>
