Home > General > Removing Mud Flaps
JustinP
Removing Mud Flaps
Hi
I've wanted to see how my FF looks without mud flaps, so this morning I set about removing them. I was hoping the holes drilled through the side of the wing trim would be small, and as my car is black I planned to fill the holes with some black silicone.
I only got to taking the offside front mud flap off, and discovered the the holes were huge, and in addition the mud flaps had worn the paint a little where they made contact with the wing.
Here's a photo incase anyone else is considering doing the same.
It's now been refitted where it will stay for good.
Cheers
Justin
Post #48973 5th Feb 2011 3:14pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Looks like you have the Chrome finish paint job in the pic justin! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #48974 5th Feb 2011 3:16pm
thats weird cos the ones i have on mine are fixed by screws in the wheel arch and from underneath... ... - .- -.
Post #48977 5th Feb 2011 4:56pm
sharpm
Scotland 2006 Range Rover Vogue SE Supercharged Stornoway Grey
The proper way to fit them is to drill through the wing
I've had range rovers with mudflaps and without and much prefer them with mudflaps combined with running boards
Post #48978 5th Feb 2011 5:04pm
that might be the proper way but mine havnt fallen off yet . Very Happy ... - .- -.
Post #48979 5th Feb 2011 5:09pm
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
Your lucky , the chimp that installed the flaps on mine had 2 or 3 goes at trying to get the hole in the right place.
I removed mine as they would have been ripped off when off roading, the holes now have some nice stainless steel washers and torx head bolts in them.
Post #48987 5th Feb 2011 6:26pm
probably lucky cos i done the job myself..but good point re off roading , never thought about having to remove the mudflaps. ... - .- -.
Post #48989 5th Feb 2011 6:30pm
Tim in Scotland
I had the LR mudflaps on my Freelander 1, I did some quite hefty offroading in that wee car and was always amazed that in 3 years I never lost one of those hard palstic mudflaps, it took about 3 outings in my Defender to loose the nice flexy rubber ones from that though! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #48993 5th Feb 2011 6:42pm
JustinP
@Tim - I originally took that as a compliment about my shiny black paint, but having seen the following photo on another thread, I would like to state that the car is definitely black Very Happy
Post #49774 11th Feb 2011 8:14pm
Googsy
Scarey
Looking for advice on how to fit the front flaps I got an aftermarket kit delivered today . Have managed to find video on how to fit rears so thats fine but apart from drilling as above how did you fit yours as i cannot see likely mounting points on inner wing as you suggest?
Cheers
Googsy Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #85377 5th Oct 2011 12:07am
it was a while back now, but as far as i can remember i just put the mudflap up against the arch and located the holes and screwed in ...i've taken mine off now and they've left no holes like justins probably cos mine are aftermarket ones ..i think there were 2 screws along the inner edge and 1 underneath...they were really dead easy to fit ... ... - .- -.
Post #85386 5th Oct 2011 8:43am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I got my mudguards and flaps removed, I much prefer the look without! Thumbs Up
Here's the before photo:
and after:
 2012 SDV8 Vogue SE
Post #85391 5th Oct 2011 9:18am
any holes left david? ... - .- -.
Post #85392 5th Oct 2011 9:28am
bozmandb9
They were doing a wee bit of paint work at the time, so I believe they stuck some chewing gum in the holes and squirted over them! Rolling with laughter
In all seriousness, Yes, removing running boards and flaps will probably require paintwork a lot of the time. I also removed the (to my eyes) horrible covers over the lights, and this left some holes too! Sort of job that if you're getting some paintwork done anyway isn't too bad, but otherwise would be a right pain!
Thumbs Up 2012 SDV8 Vogue SE
Post #85395 5th Oct 2011 9:36am
i dont like those light brackets either.. Laughing
good tip re the chewing gum though.. Thumbs Up ... - .- -.
Post #85396 5th Oct 2011 9:38am
