![]() | Home > General > Removing Mud Flaps |
Thanks Scarey I cannot seem to find any screw points on the inner wing ![]() ![]() I would be grateful if someone with a 2007 onwards model could confirm there are indeed fixing points for these along inner arch on the front or do I have to drill to fit? Thanks Present :2008 TDV8 HSE Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
ON MY 07 which has running boards there is a bolt in the bottom and one on the side bolted into the plastic wing lower panel. 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
Thanks Ray I watched a video on how to fit the running boards and saw that but as mine does not have running boards I think that is not viable however appreciate the response Present :2008 TDV8 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35643 ![]() ![]() |
googsy, sorry mate cross purposes here... when i said 'located the holes' i meant the fixing holes on the mudflaps which i then screwed into the arches and i think i might have done some pilot holes for the screws..... ... - .- -.
Right chaps after much investigation it appears I did not get any fixing brackets for the front hence my issue. Hopefully seller can send these on as they were specified in listing. If anyone has fixing brackets for front that they dont need I would be interested also.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Im sure i have some spare here... if your struggling with your seller let me know my friend...
All those I have removed/fitted where fixed from inside the wheel arch with no holes drilled in the bodywork.... |
Craig Your fast becoming my favourite on the site after Scarey and hes slipping ! Much appreciated will let you know maybe if you locate some in anycase let me know cost + Shipping via PM. Present :2008 TDV8 HSE Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
